Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
HOW TO REPLACE MY COLOR WHEEL
CAN YOU TELL ME STEP BY STEP HOW TO REPLACE MY COLOR WHEEL IN MY SAMSUNG - MODEL # HLN5065W. THANX, MIKE
    Genius:
  • 2,035 Answers
Please click on this here
Good luck...
Posted on Dec 18, 2008
    Sergeant:
  • 306 Answers
SAMSUNG DLP Color Wheel Replacement and Sourcing:
If your SAMSUNG is now making a grating, loud noise (like Mine) and needs repair...it isn't your lightbulb it is your COLORWHEEL that needs fixing. This is a compilation of two emails that I dug through and found regarding HOW TO REPLACE YOUR SAMSUNG COLOR WHEEL for less than $120...AND where to SOURCE the PART. Hopefully this is Helpful for those who
1-- Unplug your TV and disconnect all the cables at the rear of the TV. You then want to remove the lower rear panel.It's held in place with Philips screws. You then want to remove the screws holding the panel that you plug the cables into. there are several screws. Just let it hang in place. then remove the 4 screws holding the main board. You will have to remove the screw holding the fan on the lower right side. after all the panels are loose, you can pull all of them out the rear of TV to give you access to the Wheel. Don't pull too hard and pull any connections loose. However you will have to give the main board a pull to rear of the TV to break it loose. Dont worry about getting everything back in place. it only fits one way.
2--Next you want to remove the lamp. the instructions for this are in your manual. After you remove the lamp, you will have access to the two color wheel covers. one cover removes from the front, the other removes from the top. there is a hidden screw on the left on the top cover. It's hard to get at.
3--There are three screws holding the color wheel in. then just put everything together in reverse order. Just take this step by step. letme know if you run into any problems. It's not too difficult if you take your time. I ordered the color wheel from www.samsungparts.com however, you may be able to find one on EBAY for less. Samsung delivered mine it two days for $18.00.
If all looks fine u did not have to disconnect any other component; just lots of screws to remove. u also only had to remove the top cover of the color wheel. u may have one question though about the small white ribbon cable connecting the wheel. It looks like a pretty normal connector at the wheel, but where it plugs back into the component panel to the left it looks like the cable simply slides into this connector. Is this right? u see no way to take apart the connector. The backside of the cable has a blue surface where it is inserted into the connector. I'm guessing that is to provide proper orientation.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your concern has been documented and with your indulgence, the links:
Good luck and Thank you for using FixYa. Happy Holidays.
  • 121 Answers
There is no color wheel. please explin your problemin detail. thanx Joe.
Service manual to install a color wheel,for a samsung hln5065w also if you have direction
you can get the service manual which shows color wheel replacement from the following link delivered by download link within minutes of ordering http://servicemanuals.vstore.ca/product_info.php/pName/hln5065w/cName/samsung-manuals
Oct 29, 2011 | Samsung HLN5065W 50" Rear Projection...
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
I understand I need a new color wheel for our HLN5065W TV. I can get the color wheel easy from Samsung but, can you tell me how to install it without a technician? Can I install it myself? Can you tell...
U have some technical skills and machanicals skills?If you don't,u better just hire a tv Tech. to do the job or will end up costing u more money,because the tv Tech. don't like to be hire to fix people mistakes and blunders.Go to You Tube video type in Samsung colors wheel replacement.U will have a tutoring video by some one taking out the colors wheel and replacing it.
May 24, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
No color perfect picture hln5065w
Either your Color Wheel is bad or the DMD bd is bad. You will need a trained Samsung tech to look at it to determine which it is. The Color Wheel replacement is relatively inexpensive Color Wheel part# is BP96-00250A. The DMD bd is a little more but are hard to find besides you must have a trained Samsung tech to properly align a new DMD bd. Engines cost hundreds moreand are available.
Jul 13, 2009 | Samsung HLN5065W 50" Rear Projection...
Replaced color wheel
OK, THIS TV HAS BEEN A DOG,IT seems the light engine was going bad to start with so it is a good thing i diidnt replace :LAMP,or Balster,New Color wheel is working,But with BAD Light Engine Lamp will not longer come on either!
Jun 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W color wheel installation
Check the wire connections one may be loose or not properly seated
May 11, 2009 | Samsung HLN5065W 50" Rear Projection...
COLOR WHEEL REPLACEMENT
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
I replaced my color wheel on this TV using those instructions.  Took me about an hour but it worked perfectly.  Just take your time.
Aug 15, 2008 | Samsung HLN5065W 50" Rear Projection...
Replaceing color wheel on samsung tv model number hln5065w
Click here to find a tutorial on how to replace the color wheel on your TV.
Aug 13, 2008 | Televison & Video
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Henry  Thomas
Henry Thomas
