Question about Mitsubishi ES100U Multimedia Projector
Projector suddenly shut down
We recently replaced the bulb, but it continued to flash "replace bulb". Today, it was running fine, until it suddlenly shut down. There was no warning message, no noise, and I wasn't pressing any buttons. I had the timer on my SmartBoard and my students were testing when it just turned off. The power light is on, but the projector is not running.
  • hpleasant Jan 06, 2009
    I have the same/similar problem. Teacher would use freeze or mute and when leaving freeze/mute projector would shut down. Later today it would not come back on but the power light is red and there is no sound or output. I thought I might replace the bulb but have my doubts about this working.
    I have the same problem. The problem started with the machine shutting down after going to freeze or mute mode. Now I only get a red power light.
  • 2,237 Answers
You need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Posted on Aug 04, 2009
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Sled gets to 155 deg and shuts down
Change the thermostat,is the water circulating?
Feb 23, 2014 | Polaris 2006 SwitchBack FST
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
We recently replaced the bulb in my projector, but it continued to flash "replace bulb". Today, it was running fine then suddenly shut down. The power light is on, but the projector is not on.
IF you did not reset the lamp counter, the unit will shutdown. To reset, press the left and right arrows along with the power button for at least 3 seconds. That will reset the timer. Update this if that does not resolve the problem.
Dan
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen flashing
you need the voltage on the ps board and the ysustain board adjusted. Possibly the z sustain board needs replaced if this doesn't fix.
Aug 18, 2007 | HP PL4245N 42 in. HD-Ready Plasma...
That certainoy sounds like the color wheel assembly inside of the light engine is bad. The light engine is located here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00674A&search%5Fmodel=HLP4663W Good Luck
Aug 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi ES100U Multimedia Projector Logo
795 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
neOen
Level 1 Expert
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
