Question about PSC Quickscan 6500 Handheld
Scanner won't read the barcode
I hooked my scanner up to a laptop and now it won't read the barcodes. It beeps and flashes a red light. I have scanned the factory default settings and it still doesn' t work.
  • 3 Answers
You read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Posted on Dec 20, 2008
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Tip
How do I read barcodes from an Adobe PDF FILE?
<p>Reading a bar code in a portable document format (PDF) document is a simple procedure. Some newer phones come with smart barcode scanners, and you can scan the Internet to buy. A barcode is a series of lines of code that identifies a product. When you print the document with a single piece of technology, you can read a barcode in a PDF document. <br /> <p><br /> <p>1. Open the PDF document. Adobe Reader PDF reader is the most common. If you do not have Adobe, download the latest version of the company's website for free download (see Resources). <br /> <p><br /> <p>2. Select "File" drop-down box to the left of Adobe. Select "Print" and then "OK". <br /> <p><br /> <p>3. Set the bar code scanner. Jumping the gun and a horizontal red line is designed with the focus of the scanner. Move the line through the barcode printed on the document until the scanner beeps. Release the trigger and see the screen on the back of the scanner, which will give you the information encoded in bar code. <br /> <p><br /> <p>4. Download a barcode scanning application for your smart phone if you do not want a handheld scanner. Most bar code applications are free. Open the program and point the camera at the barcode in the PDF. Wait until the camera for a snapshot of the barcode will not make up the barcode in the light of the entire camera to take. The program will decode the barcode and display the results. <br />
on Jun 26, 2011 | Computers & Internet
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
Unable to scan a certain barcode, i think it's just a configuration as I'm able to scan some. I know this model works as i already have one that scans OK but was set up before my time in this company. I...
what kind of scanner is it? is it a 2d barcode that you are trying to scan?
Also make sure it isn't a printer issue: ie: barcode is too light.
Does the scanner act like it sees the barcode? beep or any other notification?
Oct 04, 2017 | Dolphin 7600 Barcode Scanner
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the...
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Oct 05, 2010 | Opticon OPN 2001 Mobile Data Collector...
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
PSC Quickscan 6500 Handheld Logo
779 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
