Question about Kenmore 43042 Front Load Washer
Blowing the circuit now
We just read the advice for our front loading Kenmore and we found a ton of stuff including a sock in the black acordian like area stated in the message. It was difficult getting it all back together. But mission accomplished. We just loaded for a test run and all is working fine except it immediately blew the cicuit now which we can reset rigth at the outlet. It wont stop doing this and we cant move forward. Any help would be appreciated.
  • Deb Zimmerman Mar 30, 2007
    Thank you so much. It was setting off the outlet every couple of seconds and did this immmediately. My husband took off the back panel and made sure the wires were not loosened when fixing. This did the trick.
    Also, as there were so much water that came out I would advise anyone who is doing this - of course to unplug everything - but also be prepared as the water can splash on the wiring ..so make sure you have a small bucket or a few towels to catch the water.
    Thanks again.
  • 67 Answers
Is it blowing the circuit immediately or after a while? try taking the front toe panel off if it runs with it off the its most likely the outlet when u take the toe panel off it opens the ground switch this will let u know if u have a bad ground
Posted on Mar 27, 2007
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Nov 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore he2 front load dryer
door switch error...implies the door is ajar..or that the switch is not working.
Feb 26, 2008 | Dryers
Tip
Four socks! Four 2-year old child socks! That's what I found inside the drainage...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
Tip
Great free advice.. Found 4 tweezers $2.00 in coins and socks. I wish this was...
on Jan 30, 2009 | Kenmore Elite 45986 Front Load Washer
The water isn't draining and the tub won't turn. I get F code
What I read on the internet suggested to check the filter. I didn't know where the filter was located. i couldn't find that information in my owners manuel or the internet. But looking at the washer I saw that the bottom section comes off..held on by 2-3 screws. I removed that lower section and found the filter, a white gizmo that I was able to turn by hand. Inside the filter I found a dress sock stuck in the filter. I removed the sock, cleaned up the filter and the washer now works GREAT!!
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore front load washer will not spin
I had the problem where my Kenmore front load washer would not go into the fast spin. The repairman replaced the spin control unit and the motor with still no fast spin. He came this morning to replace the front control board and still nothing. He then decided to replace the door/lock unit and that is what did it. After about a month, now I am able to wash my clothes and not have to hang them up to drip dry enough for me to place them in the dryer. By the way, the manufacturer said that it was either the spin control unit or the front control board. I guess they will have to revise their fix for this problem.
Mar 18, 2007 | Kenmore 44102 Front Load Washer
Kenmore 43042 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
