Question about Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer
Senco finish nailer, drive pin doesn't retract
Just shoot drive pin down and it stays down, next pull is a dud and it goes
back down not taking nails with it .
  • 2 more comments
  • be_newland Dec 17, 2008
    senco finish nailer doesn't retract, drive pin stays down in nose
  •  Jeff Petree
    Jeff Petree Aug 29, 2012
    If the piston is not seized its usually the trigger assembly the trigger valve switches to both engage and retract the piston
  •  Jeff Petree
    find your models manual and look for troubleshooting section- it usually tells you this
  •  Jeff Petree
    SYMPTOM Air leak near bottom of tool / Poor return. SOLUTION Clean tool / tighten screws or install Parts Kit A.(trigger assembly)
  • 275 Answers
Check Firing Valve: This is the key part which regulates compressed air in or out of the cylinder sleeve. In oiled tools, the firing valve is a circular piston equipped with o-rings. The no-oil tools feature a unique, inflatable diaphram that serves as the firing valve.
Posted on Dec 17, 2008
    Genius:
  • 1,199 Answers
Replace drive pin (drive pin is bent and this is causing it to stick!
This should fix ya!
    Sergeant:
    Champion:
  • 304 Answers
If you buy a reconditioned gun, ask them to hook it to a compressorer, then put a stick through it. If it doesn't jam or feeds properly, then it should be ok.
Clipped head nails, picture bullets in a gun, they are all round heads and need to be stacked so they don't jam the one below as they feed. With clipped heads, they come in sticks, its just so they don't grab the nail behind.
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
I have a senco sfn30 and it only shoots every second nail in. I had a look and the firing pin only retracts bout half way down???
that is the problem, I would take a look at the piston o ring for wear. Remove all the nails and air. BUMP the tool and see if the driver falls down and if so that would indicate a worn o ring. When replacing use a light film of oil to lubricate.
Jan 28, 2012 | Senco Air Tools & Compressors
I have a Senco pro 35 18 gauge finish nailer been working fine now I just get air when I pull the trigger
could be a jammed nail in the nose/magazine area or a driver problem. is the driver fully retracted or stuck partially down in the nose. UNPLUG the air before checking. If the driver is partially down I would think a jam and fully retracted you might have an issue with the piston/driver assembly.
Feb 11, 2011 | Senco Tools & Hardware - Others
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Driving piston will not retract after first nail. There seems to be a lot of air coming out of the back of the tool. The O ring under the ring in the air chamber has never been changed. Can the ring and...
go to Senco.com and type in your model number and you will be able to buy kits to fix this tool. the kits come with detailed instructions on instalation.
Dec 02, 2009 | Senco Tools & Hardware - Others
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Senco finish nailer, drive pin doesn't retract up to take another nail...
Senco nailers are very reliable however could suffer from several issues that would cause your problem. Here are a few things to check that may solve your problem. Bent driver, worn parts, broken check valve. Main problem with all finish nailers is bent driver blade. Easy to check, remove and examine. The driver should travel length of cylinder without jaming. Driver oring/plastic ring should fit snug into cylinder. Remove cylinder and check the oring neer the bottom of the cylinder. This is a check valve. There are small holes that should be cleaned. If oring is loose or broken just use any oring that fits snuggly. Next, check that lower bumper is not chipped or cracked and that washer under bumper is not too worn or missing. Replace parts as necessary. (www.toolpartsdirect.com)
Enjoy
Dec 17, 2008 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer Logo
350 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
