Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Why does my washer make a very loud noise when spinning out?
When my washer goes into the spin cycle it begins to make a loud noise and continues to get louder as it sppeds up. The outside of the machine does not move.
  • tap8895 Dec 17, 2008
    My washer is making a loud noise during the spin cycle. Your advise was that a belt was broken. How do I replace this myself and where do I get the part?
    Your advise to me was that my machine needs a belt. The washer makes a loud noise during the spin cycle. Can't I replace the belt myself without calling a repair man?
  • 275 Answers
Belt is not broken, but it might be cracked or loose..you might need to replace it. Untill this has a beld tight enough it will stop shaking
Posted on Dec 17, 2008
    Brigadier General:
  • 5,158 Answers
Sure you can repair it yourself .... good way to save money and have pride in doing it yourself.... just make sure you get the proper belt for it.
Robert
  • Bosch Master
  • 19,396 Answers
If the belt is broken the machine does not even spins, and therefore does not make this kind of noise, just humms.
In your case the belt is not broken,
if the noise is a kind of rattling noise, then there is an object in the foreign object trap, where the drain pump is, there is an access panel to access the trap and the pump.
If the noise is a kind of loud rumbling noise and the drum has excessive up and down movement of the drum, then the drum bearings are gone and must be replaced.
In both situations it is better calling a technician.
    Master:
  • 416 Answers
It it makes noise during spin cycle it can be just unbalanced. Try to stop it and rebalance the cloth inside it.
It might be also that a little piece of cloth gets outside the spinner. Try to check it for that too.
Unfortunataly sometimes that happened.
Good Luck
    President:
  • 373 Answers
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
    Top Expert:
  • Bosch Master
  • 81,400 Answers
If the belt was broken it would not spin, but it may be loose or burnt, to replace the belt remove the back panel of the washer, check to see that the belt is the issue, if it looks burnt or cracked lay the washer over onto the front this will give you access to the belt, from there it is pretty straight forward as to what u need to do to change the belt.
  • 679 Answers
It sounds like the belt is broken shut it down to prevent more costlly damage, you need a repairperson to fix this it needs a part, thanks, Gym
  • George Bill
    George Bill Dec 17, 2008
    Here is what I think it is. It sounds from the description that the belt is starting to go, but not yet gone, so that would account for the noise getting louder as the speed increases. Now some of these european machines have all sorts of electronics on board, almost like a mini-computer. If you are handy enough to feel comfortable opening it up, and you are off warranty, you really have nothing much to loose. But the type of machine you have is expensive, and I wouldn't advise you to fool with it unless you feel comfortable doing so. It may be a bolt that came loose or any of several other things, the belt is inexpensive, so I would definitely try that first, you would be able to see the problem if you could open her up first, and if we got lucky that will be all it was. Did you call Bosh and ask them about the problem. Sometimes they will say something like ok that sounds like a belt, or some other part. Me not being able to diagnose it much further without seeing and hearing it makes it difficult to say with certainty that is what it is,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Check out with dealer you purchased it. may be the there is the problem with spinner. timet to replace it
  • Cloudbooks Dec 17, 2008
    check your water pump, if something gets in it or the water pump
    bearing is bad, it makes this kind of a sound. And since you claim it
    makes the sound when its not spinning as well, that makes me believe
    its the water pump.
    Take the lower front panel off then you'll see the drain pump with the
    2 large rubber hoses attached to each end, get something to catch the
    water in, then remove the hose clamps, and see if something is in the
    drain pump, you can also remove the drain pump itself, by just taking
    out the 2 5/16" bolts that mount it to the washer base.
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
1,032 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
