Question about HP LaserJet 2840 All-In-One Printer
Black streaks when coping
Why does our 2840 leave 1/3 of a section of the paper black and fades away on the other 2/3 rd's? It has done this since it was about 1 month old....
Larry
  • michelleann Apr 12, 2009
    I have the same print problem, 1/3 of the page prints and 2/3 of the page does not. I replaced the black cartridge, it ran through a self-clean mode and it is still there.
  • 44 Answers
The carousel that the toners are in has probably slipped a tooth on one of the gears at the sides. Look at the toners while they are in place and check that they appear level and consistant when compared to another straight edge adjacent to them. The carousel timing will require adjustment if they are not level.
Posted on Apr 20, 2009
    Guru:
  • HP Master
  • 829 Answers
To perform a clean reset:
1) Press and hold the Calendar button, the Power button, and the Messaging button.
2) While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
3) When the Pocket PC screen begins to fade, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Make sure you hold the keys down long enough.
Posted on Mar 22, 2009
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
HP 2840- vertical black streaks on paper edges when copying using black only- copies fine in color
The Drum unit is worn or defective. try another drum unit. this should take care of your problem.If it's new then get your money back and replace it.
Dec 10, 2009 | HP LaserJet 2840 Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Black streaks through pages
There can be some reasons:
1. The Fuser is too cold, so toner was not fixed
2. Image Transfer Belt is defect or dirty
Greetings from Germany
Mar 13, 2009 | Samsung CLP 300 Laser Printer
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Black steak on copied paper
Clean the scanner glasses, check the little glass, if it have scratches. There is a white strip across between the 2 glasses, be shure to clean it up.
Oct 23, 2008 | HP LaserJet 2840 All-In-One Printer
Black streaks on paper when printing message
That green bar is the drum unit. Black streaks are indication of bad drum. Replace drum unit. Don't wait too long or it will ruin the fusing section as well from excess toner build-up. Big bucks!
Please do not forget to rate your replys please.
Nov 21, 2007 | Sharp FO 3500 Plain Paper Laser Fax
HP LaserJet 2840 All-In-One Printer Logo
102 people viewed this question
Ben Johnson
