Question about Onkyo TX-SR700 Receiver
Onkyo Zone 2 problem
Cannot play the audio input from Video 2 (my television) through the remote zone (Zone 2). All other inputs; DVD, CD and AM/FM Receiver work OK. Anyone have any ideas, as the manual is a disaster of technical writing failures?
  • Anonymous Nov 20, 2008
    my sr 700 will not play cd's thur the zone 2 speakers. tv and tuner ok
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
Posted on Oct 29, 2007
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
Onkyo zone 2
Is it possible that the currently selected input was changed? Try selecting a different input.
Jan 31, 2014 | Audio Players & Recorders
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
My television picture does not appear on my zone 1 and zone 2 television. I just get a blue screen although I get audio. The crazy thing is that when the function is set to DVD. I get the picture. I...
Hi. Most likely the assigned input isn't correctly setup. Try this:
1. Press 'setup' on your remote control.
2. Navigate to 'Input Assign'.
3. Navigate to the correct next option (HDMI/Component/Digital) - this depends on how you have connected your DVD player up.
4. Find the name of the connection you've plugged your DVD into (physically look at the back of the receiver).
5. Select the DVD option, and press left/right until you have selected the correct input.
You may need to change to Tuner then back to DVD, but that should do it.
If you need further help, please let me know exactly how you've connected your DVD player (HDMI? component?), and the name of the physical connection you've plugged into.
Hope that helps!
Mar 04, 2011 | Onkyo TX-SR876 Receiver
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
May 01, 2010 | Onkyo Audio Players & Recorders
Zone 2 audio output is for analog only? The only reason I bought this receiver was to be able to play my ipod on our outdoor speakers.
David is wrong. My Onkyo is the same way. The receiver will only provide a signal to zone 2 speaker outputs from analog sources. I assume this was because of concerns with digital rights management, which caused some odd decisions for a while by hardware manufacturers. Newer receivers should not have this problem.
Apr 26, 2010 | Onkyo TX-SR606 Receiver
Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
May 26, 2008 | Denon AVR-2105 Receiver
Zone 2 Can't Handle a Digital Input ? ! ? ! ?
it is very frustrating... I just have discovered today. I can't solve this because my Itunes mac is only digital audio output, I can share its sound to Zone 2..
Apr 16, 2008 | Audio Players & Recorders
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Onkyo TX-SR700 Receiver Logo
568 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
