Question about Nintendo DS Lite Console
Ds light won't work with R4
I've inserted a R4 into a ds light but it won't read the card, if i put a game into that slots it works fine, also if i put the R4 into another ds it works fine.. any suggestion.
Thanks
  • samemerson Jan 12, 2009
    i have the same problem, i have to old style ds's one recognises the r4 card, however the other does not recognise it at all, help!!!
  • Anonymous Jan 17, 2009
    my friend has the same problem I actually found some information just googling which said to put a piece of paper or card behind the card (cut to the same size of the card) to push the contacts as it could be a problem with contacts not touching...and it worked for me but not my friend, so any other suggestions would be great...
    Sergeant:
  • 205 Answers
Try the "fix" posted above by Guest, I've had that work for me in several different cases.
Posted on Jan 29, 2009
  • 137 Answers
SOURCE: ds lite wont read r4 card
hang about its even reckonising the card? let alone booting into the menu? sure you dont have a duff card? i had 2 of those, sent em back got replacements that work brill.
Posted on Apr 07, 2009
  • 30 Answers
SOURCE: Error message. there is no card inserted in the game card slot
have you tried another game on it if another game does work then its the game if the other game doesnt work then it the console needs to be repaired or replaced
Posted on Jun 21, 2009
SOURCE: R4 card not recognized
Same thing happened to my DS. Did you fix yours?
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Recently had to replace card slot on my Ds lite as
i have the same problem today r4 doesnot work but original games work. bought the card slot from ebay . is it a problem with the new slot?
Posted on Sep 16, 2010
  • 1139 Answers
SOURCE: I have 2 ds lite. Not used for a while. Charged
This is a very common problem for the Nintendo DS. What usually causes it is bent, damaged or worn pins within the slot where the cards are inserted. While this is not the end of the world, repairing this problem can be a little bit of a challenge. You can purchase a new card reader from places like ebay, you require something like this -
http://cgi.ebay.co.uk/FITTING-KIT-DS-LITE-GAME-CARD-SLOT-FAULTY-REPAIR-/300389534305?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item45f09c8a61
If you are pretty good with a soldering iron then you should be able to replace this part quite easily, however if you are unsure and have a friend that deals with electronics then it may be better to let them change it as the old socket has about 15 pins that are surface mounted onto the DS motherboard. Careful desoldering is needed. I have personally changed many of these and not had a problem myself but if you are not confident please dont attempt it!
I hope this helps and thank you for using FixYa
Posted on Jan 03, 2011
Unit does not read game card
Blow in the NDSL card and the slot 1 (Avoid blowing with spittle).
If you use R4/Acekard/etc.:Look for dust/dirt in micro sd card. Clean it.
Not working? Probably the problem is slot 1 connector. Need to change it.
Jan 19, 2012 | Nintendo DS Console
R4i nothing inserted in slot 1 ?? how do u fix it?? before it worked fine but now it dont
have you tried re formatting the r4 card ?? or even just unloading & reloading the games & files??
This worked for me previously
May 26, 2010 | Nintendo DS Lite
Had the r4 card for ds lite has worked perfectly for 6 months put a new game on last night ds says there is no ds card inserted tried the r4 on my daughters ds lite works on the ds lite i am having...
I think you need to update the R4 software,dont know what is your R4 update website?
you know ,there are many version of r4, If you are in UK,i suggest you visit www.logictoyz.com
Mar 22, 2010 | Nintendo DS Lite Console
R4 in NDSL freezing
The only thing i can suggest is to go to the site that is on your card and download the new firmware for your card, it maybe that you just need to update your card, if that dont work you may need to buy a new card, i would not leave your card in the nds if you are not using it for a while, take it out, dont leave it in the nds, it maybe that the contacts are worn.
Sep 28, 2009 | Nintendo DS Lite Console
DS does not read my R4..says There is no card inserted HELP?!?!
Listen this will work. TRUST ME. If you DS says "no ds card detected" but it will detect regular games, there is nothing wrong with the ds or the card. Take a piece of paper, cut it the size of the R4 card (a little longer) then fold it over and place it on the R4 card (same side as sticker on R4card) then put them both in at the same time. This will push the R4 card closer to the pins and it will work. keep trying. Took 3 tries for me and it worked. The idea here is to push the R4 card closer to the side and therefore making a better connection. THIS WILL FIX IT.
Jul 13, 2009 | Nintendo DS Lite Console
How do I insert my r4 card?
the normal ds does work with the original ds, i have 3. lol. the r4 cart goes in the top of the ds in slot 1, it obviously about the same size as the r4 cart, have ur ds so it facinf downwards to the ground, and insert the game facing upwards so you can see the r4 wording on it, slot all way in until it clicks in, then power up.
Apr 11, 2009 | Nintendo DS Lite Console
R4Ds not working on NDS I
oh sorry didnt read your post right the first time, you have a new dsi? nintendo have been clever in not only makin the dsi region bound unlike the normal ds lite, meaning it will not play games from other regions where as the ds lite can but it does also made sure that the new dsi does not support any super card, be it the r4, dstt, n5. they are gits. the r4 ,dstt teams etc have promised to do cards that the dsi supports but dunno wen avalible yet and im guessin will cost more, sorry to let you in on this gimmick that nintendo have caused.hope this helps.
Apr 09, 2009 | Nintendo DS Console
Problem with r4 and ds lite
Try the paper shim trick first. It could be that the older NDSL's slot one contacts have become "sprung" and aren't making good contact.
Cut a piece of paper slightly narrower but longer than the R4. Put it on the non-contact side of the R4 and insert the R4 (with the paper on the back) into slot 1. It may increase the thickness of the R4 such that the slot 1 fingers now make contact.
Jan 12, 2009 | Nintendo DS Lite Console
Ds does not recognise R4
Try eject, blow into the port then reinsert. There is a possibility that your ds has blocked the r4 from being used on that ds.
Dec 31, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
407 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
