Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite calypso waher
I have gotten these codes today while trying to wash a load of clothes, pf, ob, cL, so I had to take the still very wet load out and tried to let it drain and spinn itsself out but its NOT happening. What is the issue with this machine, its been a pain sense the first 6 months i had it, its one of the first ones out so i am learning that they have problems and of course Seard doesnt stand behind thier product so im stuck, should i be looking to get a new one?
  • 8,197 Answers
The "PF" error code indicates a power failure to the dryer. To clear the error code, press Stop/Cancel.
If the Stop/Cancel button does not clear the problem you will need to replace the control board on the dryer. The part number for the control board is 3976611, in case you need it.
Ob code = out off balance
cl code =
If the door is securely closed & the CL error code appears, I would recommend checking the door lock switch & wiring harness to the door lock switch. Other possibility; control board.
Posted on Dec 18, 2008
There was a class action lawsuit settled in 2007 over this specific washer. Mine had $200+ repairs about every 9 months for 3 years before I started have multiple problems in a single day. The repairman said that the the tub and motor simply did not have anything left to be used as secure mounting areas. It was OB (out of balance) and cL (lid was no longer closing properly) and pf (failing to maintain sufficient, stable power to all parts) because most the inside of it no long aligned due to failing mounting and housing. Maybe the techs on here can say if he "blowing smoke up my dirty laundry!"
Posted on Mar 15, 2009
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Calypso waher ld and ob error codes...what is it?
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
319 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
