Question about RaidMax NINJA 918 ATX Case
RAIDMAX no post
Just got a new Raidmax in yesterday, powered on...and nothing. I know very little about computers, and this is very disappointing. The computer powers up, but nothing displays on the monitor. One monitor is a brand new LG, the other is an older hp pavillion. Tried both, but got nothing.
  • ardation May 11, 2010
    depending on the configuration on your computer there maybe two locations to plug the monitor in, if there are then try plugging it into the other one.
    NOTE: if the connection which works is the one toward the top of the case works then your computer maybe incorrectly configured. See your Motherboard manual for more information.
    New Friend:
  • 46 Answers
Hi there . Sometimes Memory cards bring this problem if not seated correctly on the expansion slots. Try this remove them and put them back again then try the machine .
If there is no VGA display swap the memory cards with another of the same value .Put it on if no display ? Look for a VGA expansion card this should give you display . Good luck dude
Posted on Feb 13, 2018
aceltix
  • 119 Answers
SOURCE: i broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Posted on Feb 03, 2008
aceltix
  • 119 Answers
SOURCE: Raidmax Scorpio 868
yes they are.try to change it
bhagyesh
  • 6 Answers
SOURCE: Problems with Raidmax RMX-SRS/WS
CHECK FOR UR SMPS AND CALL LOCK IT
Posted on Feb 21, 2008
SOURCE: Doesn't power up anymore
same problem
Posted on Oct 13, 2008
cpt_cavman
  • 69 Answers
SOURCE: How do you open the Raidmax Sagitta side panel?
you need to slide to the rear about 1-1 1/2 inch and it should pull away at the rear and hinged at the front....
Posted on May 18, 2009
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Brand new case, just bought it from new egg, power light not working!
sounds like u didnt install the connector on the right place.read the mother board very closely it has a diagram usually in tiny letters
Dec 23, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
NEED HELP 8(. GAMING CASE
case sounds fine, a little iffy on the power supply.
Feb 20, 2010 | Computers & Internet
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
use a test pen and check if any power coming out from the power supply cable e.g. to hard drive, motherboard and so on.. this will help to to find out if it is actually power supply issue or components issue....
Aug 29, 2007 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
RaidMax NINJA 918 ATX Case Logo
53 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
