Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Internet keeps dropping out using this router
My question is why does this keep happening? Before purchasing this router I had an older Linksys router that would not let us browse the internet using wireless at all. It was replaced with the new Netgear router which installed and set up everything with ease. It worked for about an hour, then dropped out. About 20 min. later, it worked fine again. Then 30 min. or so later, dropped out again and the circle begins. Our ISP is going to charge us $65 for the service call if its not an issue on their Im just trying to cover anything I can beforehand. There are 2 computers hooked up to the wireless. Both experience this problem and are running Windows XP with Firefox for the browser. When directly connected to the modem service is fine, though I dont know if it would drop out after extended periods of time. The network connections link shows service is connected and is sending data out...but freezes when trying to recieve. This is all so frustrating.
Thanks for any help.
  • jjcarter5 Dec 17, 2008
    I wish that was an option. I just moved here not to long ago and dont have any friends in the area at this time. Thanks for the idea though, if I find someone willing to try that Ill definitely give it a shot!
  • ctovrea Dec 17, 2008
    My connection says 4 out of 5 bars when I connect, but then 10 seconds later the internet will drop, then reconnect, then drop, then reconnect again. I can't stay connected for longer than one minute.
  • 40 Answers
One simple solution, can you try using the router on another ISP connection (at your friends' place possibly?) This will rule out the possiblility of your ISP fault saving you $65 straightaway...
Posted on Dec 17, 2008
check your router signal strength ,if it is low then it can drop internet connection..
you can try to reboot..its a good option....:))
if everything fail then try to connect using cable and ping with proper IP address and check router signal strength .......
If you need any kind of technical assistance you can contact support cell at
Nov 29, 2012 | Linksys Wireless-G WRT54G Router
Since getting a new Dell laptop and Linksys E1000 (also have HP desktop), my internet connection keeps dropping (no problems ever before)- sometimes I can stay online for 2-3 hours or it can go in 15...
we need to first figure out whether it the modem or the router which is dropping the connection.
Please connect one of your computer directly to the modem, by pass the router and access the internet. If the connection drops then its the modem which is dropping the connection and you need to contact your isp to check it.
If the internet works fine directly with the modem then its your router which is dropping the connection. To fix the router we can upgrade it firmware.
To upgrade the firmware please visit the link below;
Note; If you are not comfortable upgrade the firmware then don’t do it. If not done properly then it can damage your router.
Aug 16, 2010 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
After 30 min connected to the internet I am dropped from the internet. It says I am still connected to the Linksys router. It sems that It is timing out. What to do? Do I need to download new firmware?
Check the "keep alive" settings in your router, there is usually a choice between having it constantly "pinging" to keep the connection open, or letting it disconnect when it has been idle for awhile. Make sure it is set to "keep alive". The wording may be different but it will be something along these lines. Go in your browser to the wireless router's configuration page (i.e. ). Depending on what brand router you have this ip address will vary, consult your documentation for which number is used.
Changing these settings may also help...  Wireless Router Configuration - Advanced Wireless Settings
Jan 27, 2009 | Linksys Wireless-G WRT54G Router
Keep lossing connection
If the Lights on your cablemodem indicate that it has lost connection with your Internet Service provider when the internt is "broken" Then it meens you need to call a cable-guy... your cable signal can varry throuought the day, and when it "drops" its too low for your modem to be happy with...
Jan 25, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Internet keeps dropping off
On the router's Setup Page / User Interface, adjust the MTU to 1400 and choose the option Keep Alive. That's under SETUP tab.
Sep 12, 2008 | Linksys WAG200G Router
Wireless g wrt54g router
First of all, are you connecting with a PC or a Notebook?
If you have the Linksys router, you should replace the MS utility with the Linksys utility it figures your linksys wireless lan card
There are programs you can use to keep track of your router and connections...One such program is called Port Mapper...
Does your problem happen everday...or every 3 weeks...are you doing anything in particular when you are getting the inability to use the connection?
There is a new Vista patch out there I recommend downloading.
Feb 24, 2008 | Computers & Internet
Linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
Nov 27, 2007 | Linksys Wireless-G WRT54GS Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
303 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
