Question about Krups Small Appliances Espresso Machine
Krups 897 Hi I noted your problem and believe I have the same water leakage. I am struggling to open the 897 - I have removed 4 screwsw at the back and 4 at the front but it is reluctant to come apart further than an inche - is there a knack or does the top need to be prised off? your help is appreciated
  • 36 Answers
SOURCE: krups water level problem
cpg1959:
it looks like your coffee maker has a LCD display panel driven by a discrete electronic circuit board inside. similar to brita water filter which is driven by an integrated circuitry. be honest with you, many manufacturers' product designers, especially today's new generation, they only look on good and fancy side and forget about durability, yielding a lot of junk products. unless it is still covered by warranty, otherwise, don't spend good money on bad, just ignor the warning, or disable the warning if you could.
pc-cook
Posted on Jan 25, 2008
SOURCE: Lots of disturbing noises, no coffee
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
Posted on May 12, 2008
SOURCE: Krups type 897, nespresso: Water leaking
I swaped the hose around.
The o-ring at the element end is bigger and can be held in properly by the clip at the pump end. The bracket/clamp at the element end holds in the smaller o-ring sufficiently.
Posted on Oct 14, 2008
  • 17 Answers
SOURCE: Hi. I have a Krups XP7245 combination
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Posted on Aug 15, 2010
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
Krups 897 stops after pushing the cup-button.
my friend i don't quit under stood but it sound like you have problems on the PCB give more info
Feb 26, 2016 | Krups Coffee Makers & Espresso Machines
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
I need a user manual for a Krups 897
http://www.coffeemachinemanual.com/krups-f-897
Aug 01, 2014 | Krups Coffee Makers & Espresso Machines
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
Nov 14, 2010 | Krups FLF2 Cordless Electric Kettle
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle leaks
You cannot fix it when they split like that.
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
Water won't flow out of espresso machine
Did you check to see if the heating element is not open?
Sep 09, 2017 | Krups XP 4050 Espresso Machine
Krups xp 7240 cofee machine says error code 06
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Nov 01, 2008 | Krups Small Appliances Espresso Machine
Krups type 897, nespresso: Water leaking from top of pump. I've opened the back of machine and found that when the pump starts the water is shoting out at the join to the clear hose. The leak reduces when...
Oct 11, 2008 | Krups Small Appliances Espresso Machine
Krups Small Appliances Espresso Machine Logo
111 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
