Back to:
Tags:
Samsung SyncMaster 740N 17
A pink vertical line appears suddenly on the screen (by 6 users)
posted by maverik on Apr 09, 2007
My Samsung SyncMaster 740N monitor is just a week old, and a pink vertical line appears on the screen suddenly. It disappears if I shake the screen or press the monitor edges of the monitor. It doesn't go away by restarting or turning off and turning on the computer. What could be wrong? please help.
Comment by maverik, posted on Mar 28, 2008
The solution (maybe the ONLY) is to exchange the monitor for a new one. That's what I did. It's mostly free if under warranty.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by ts1sds, posted on Jun 23, 2008
I purchased a ChiMei CMV 221D 22" LCD display about 3 months ago. It worked perfectly until two weeks ago, when the infamous pink line appeared on the right side of the panel. No amount of powering off & on, playing with the buttons, or shaking worked. Then like one of you mentioned, the line would come and go intermittently - no rhyme or reason. Well, last week I found the reason, and maybe this will help one of you. My wife bought me a perpetual-motion desktop gadget featuring a chrome rod and ball sculpture that's supported on two poles over a base. Give the rod and ball a push, and it rocks back and forth forever. It can do this because there is a rather powerful electromagnet in the base, powered by a 9-volt battery. The ball contains a magnet also, and is repelled each time it passes the base, thus causing the motion. These magnets were affecting the flat panel display. Whenever I happened to push the sculpture close to the terminal, the line appeared. If I happened to move it back, the line disappeared. I finally placed it on a shelf away from the display and have not seen the line in four days. This could possibly happen with any powerful magnet placed close enough to the flat panel to interfere with the pixels. If any of you have placed any speakers near your display recently, or anything that might contain a magnet, move it further away and see if that resolves the problem.
Comment by Guest, posted on May 28, 2008
I have purchased a new Samsung SynkmMaster 740N led monitor two months back.Suddenly a pink vertical line appears in the monitor.,and goes of its own.The computer attendant not able to solve the problem.How i can solve it?
Comment by Guest, posted on May 27, 2008
I have purchased a new samsung syncmaster 740N two months back.
A vertical pink line come some times(not always) The computer person
several times attended to clear the fault.He is not taking the moniter for repair.
What can i do now?What may be the fault? pls help.
Comment by Guest, posted on May 21, 2008
I have a sharp LC-19 inch LCD and my 3 year old son play video game. He hit the screen with the controller and suddenly it has a vertical line of diff colors like pink green red on the right side of the screen. Everything is still working except of that vertical lines of color? Pls help.
Comment by Guest, posted on Dec 26, 2007
I have the Samsung 941BW and I have the same pink line after only two days.
Best Solution
posted on May 30, 2007
Helpful (85)
kantakee
Rank:Apprentice Apprentice
Rating: 76%, 11 votes
you must change panel
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on A pink vertical line appears suddenly on the screen:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
The only option is to exchange it for a new one if it has warranty.
Thank You!
Solution #3
posted on Apr 04, 2008
Not Rated (0)
akhil154
Rating: 100%, 1 votes
even i formated my pc.but still problem is there.help me how to correct vertical line on monitor...kakhilesh83@yahoo.com.....thank you......
Thank You!
Solution #4
Not Rated (0)
akhil154
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Thank You!
Solution #5
posted on Mar 27, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I resolved this problem by exchanging the monitor for a new one. I guess that's the thing to do if your monitor is new and under warranty.
Thank You!
Solution #6
posted on Mar 26, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
**** ur laptop screen.. try a ***** with usb.. it'll set its mind right
Thank You!
Solution #7
posted on Jul 13, 2007
Not Rated (0)
kbzaloka
Rank:Wiz Wiz
Rating: 76%, 67 votes
try to resolder the mainboard, taking care not to leave short circuit where isn't needed...
Thank You!
Can you Help with these Monitors problems?
Samsung SyncMaster 740N 17" LCD Monitor
I purchased this monitor 8months back.Now i have this...
I have an issue with a 740N LCD and need to open it to see...
whenever i turn the pc on, the monitor starts blinking. it...
when switched on the monitor shows a dullish image with...
can someone give the spares parts dealer for samsung lcd...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
