Question about Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin when filled with water. Makes loud noise
The washer section of my machine does not spin therefore the clothes are not being washed. Machine makes a loud grating noise when turned on especially when filled with water. The spin-dry section workes fine.
  • 3 more comments
  • Cheryl Clarke Dec 18, 2008
    Thanks for your help. I believe I will have to call in a qualified technician as suggested.
  • crowley259 Jan 28, 2009
    my washer doesn't spin at all i took it apart but there is no belt to spin it so that is not the problem. what makes the washer spin without a belt
  • Anonymous Feb 07, 2009
    I have an old Whirlpool Washing machine, model LFA5800N1, (mid1970's) that doesn't spin. There is an accumulation of soot in the clutch. How do I clean it? Please respond ASAP as I hate going to the laundromat and have had this scenario for a couple of weeks.... thank you....
  • Anonymous Mar 15, 2014
    washing machine stopped working befire it could spin out water
    motor want spin are fill water
When a washing machine does not have a belt, it spins via the motor coupling. Usually when a washer is not spinning, it is caused by a broken motor coupling, which is a plastic triangular piece in the motor. It is a pain to get to, but with a little time and some instructions (search the internet for instructions for your model), the repair can cost as little at $15.
Posted on Apr 27, 2009
  • 100 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Dec 17, 2008
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Turn the machine on and it fills with water but when it gets to the agitateing the agitater does not move and just makes a loud clicking noise, ( coupler maybe)?
If it pumps out the water but the washer won't spin out the clothes then yes the coupler is broken.
To check it out flip the controls and remove the case. Very easy repair, only a few tools needed.
themobilian_1680.jpgthemobilian_1681.jpgthemobilian_1682.jpgthemobilian_1683.jpgthemobilian_1684.jpg
Video how to:
Service manual and more HERE
Mar 03, 2011 | Kenmore 22422 Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Makes a grnding sound when washing(not always) & does not spin all the water
This problem happen to me a few months back--washer was 6 months old. A technician came out and told me that I must have loaded the washer after the water was in the tub. He stated that I must load my washer prior to running the water in because the water fill amount is based on weight; therefore it was now weighing too much. Go figure...have always loaded the washer with water first and clothes last. I always put clothes in first then the water--I must say, the problem has not reappear.
Hope this helps.
Nov 03, 2008 | GE Profile WPRE6100G Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
515 people viewed this question
Dan Webster
Dan Webster
Sal De
