Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
No power on my emachine
I got a desktop emachine from my brother and it has no power .. i had the ps checked and it is getting voltage does that mean it is still good and if not what else could it be.. please email me at john.scaife@thule.com
    President:
  • 2,992 Answers
The power supply might be okay but the system board could be bad and not turning the power supply on when you press the power button.
On this page:
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
about midway down is a nice diagram of the power plug from the supply.
If you take a short jumper like a paper clip and touch the
PS_ON pin to the ground pin on either side, the supply will turn on if it is working correctly. You'll know cause the fan will start. If the supply turns on the system board is the likely cause. Check for an obvious problem like the cable to the front panel switches having come off the board.
The boards in eMachines are a common trouble, but there could be something connected to the board causing it not to respond. Try disconnecting the cables from the board to the drives and remove the memory, and clear the CMOS (either remove the round backup battery or use the jumper that's normally in the same area). Try the power switch again, and if the unit still doesn't start up it's the board.
Posted on Dec 17, 2008
  • 8 Answers
Open the machine - try to change the SMPS.
Hope the Power-oN button is not the problem.
Else there could be many reasons.
Does eMachines EL1352G-01w (884483537679) PC Desktop support atx power supple if not what does it support?
Look at the cables. If you have 2 cables from the power supply that look like the picture below, it is an ATX PS.
You should have a 24 pin and a 4 pin connector.
Thanks for using Fixya.
Apr 22, 2011 | eMachines EL1352G-01w (884483537679) PC...
My Dell inspiron 518 will not turn on when power button is pressed. Green LED on back of power supply lights and orange LED on motherboard turn on. No fan operation on anything. Thinking it is the switch...
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
Feb 14, 2011 | Dell Inspiron 518 Desktop Computer
No power in emachines w6409 desktop
check for short cicuit on the motherboards and on the pheriperals, the PS will not turn on if it can sense any short circuit on the component attched to it, if it work before turning off check the wattage of the PS
Dec 04, 2009 | Computers & Internet
Does a HP Pavillion T3000 need a fuse? Power cut
It can be the problem voltage variation. The mother board might have some problem. Please check the motherboard for any burnt parts. If there are changing is the only option.
Thanks
Aug 16, 2009 | HP Computers & Internet
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
EMachines 2824 not powering on
you can check also by removing the boards.you can check the mainboard outside in the box..you remove the mainboard and check if the mainboard is not shorted with another devices.
Mar 07, 2009 | E-Machines (T2824) PC Desktop
W2686 eMachine doesnt turn on after changing powersupplies
hi im josh in cebu phils.may i help you? Friend if the pc does'nt power on even you have replace the power supply. it means that there is a major problem in your hardware definetly if not the power suppy the motherboard or the processor.be sure to have compatible mainboard and processor because there are mainboard that does'nt support a certain processor please try to check it .try to replace another motherboard that is compatible to your processor. or check the connection of the power on button and the wires from supply to motherboard.please do that to solve your problem hope i helped you good luck.
Feb 25, 2009 | E-Machines eMachines W2686 PC Desktop
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Emachines t2984 that wont power up
Make sure the RAM is seated properly and recognized by the coputer bios program.
Mar 25, 2008 | E-Machines eMachines Refurbished EMA...
Emachine T4060
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
ps: if the mainboard bottom was in touch with anything metal from the case otherwise it might get damaged
Nov 13, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
113 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
