Question about Nortel T7316E 2-Line Corded Phone
Want to pick up phone and get an outside line
Currently when we pick up the phone with our Nortel T7316E, it picks up an intercom line. Is there a way to program the phones so they will immediately go to the first available outside line without having to press the line number?
  • Anonymous Mar 13, 2014
    when I try to get outside line it says pick up denied. All other phones in building work fine. Tried a different phone and it did the same thing.
    Problem Solver:
  • 18 Answers
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Posted on Oct 01, 2009
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Nortel T7316. We use auto assistant. Message picks up immediately. I want the receptionist to answer live and if she does not answer after a couple of rings for auto assistant message to kick in. How can I...
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
May 09, 2010 | Nortel T7316E 2-Line Corded Phone
How do i transfer a call with my norte t7316e
There are 3 Flexible Feature buttons under the horizontal display. When you are on a call, the display will show "Transfer" over the last button. Press that button, which will automatically put the caller on hold, pick up an intercom and prompt you to enter the extension to transfer the caller to. Enter the ext. number and tell your employee who is on the call, and heng up - the caller will be connected automatically. Or, after dialing the ext. to transfer the caller to, just hang up and the call will ring through. Good Luck!
May 05, 2010 | Nortel T7316E 2-Line Corded Phone
Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Feb 09, 2010 | NorStar T7316E Phone
How can I use the intercom to talk to someone in another room?
FEATURE 66 AND THE EXTENSION NUMBER. PICK UP YOUR HANDSET AND TALK AND LISETEN. YOU CAN ABUSE THIS BY DOING IT WHILE SOMEONE IS NOT THERE AND THEN LISTEN WHEN THEY GET BACK. BE CAREFUL.
Feb 02, 2009 | Nortel T7316E 2-Line Corded Phone
M7310 phone buttons
Wow, you should get 2 lines and at least one intercom by default. Lines are assigned in most Nortel systems in Terminals & Sets. Your COPY command is your friend. Just pick a phone you wnat to emulate and copy it to your new set.
Carl
Sep 01, 2008 | NorStar M7310 Corded Phone
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
704 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
