Question about Panasonic DMR-HS2 DVD Recorder
HDD won't work after Power failure. Re-format failed!
I had the DMR-HS2 for 4 years without a single problem but that ended a week ago when we had a power outage. When the power came back on, it went through the usual recover sequence but this time, it says error with HDD and asked if I want to re-format. I have tried to select "NO" and hope that it would return to normal eventually but that didn't work. As much as I hate to delete all my saved recordings, I selected "YES" to re-format but after waiting for a minute or two, the display show "Format Failed". I have tried this several times but same result. The DVD player operates OK, just not able to use the HDD. Can anyone help?
SOURCE: Self-Check Problem
U61 ERROE MINS
Posted on Apr 19, 2008
SOURCE: Panasonic DMR-HS2 DVD door won't
dvd player just keeps on loading
Posted on Jul 06, 2008
SOURCE: Panasonic DMR-E85H Not Starting up from standby
The following did the trick for me (self-check loop problem).
Replace the STRG6353 power regulator chip on the power board. The original costs about 30 euro, a clone (which I used and seems to work just fine) costs about 7,50 euro. (I got it at www.lejos.nl)
The power board is located underneath the HD drive.
Hope this helps.
Posted on Jul 27, 2008
nokurajesh
  • 101 Answers
SOURCE: dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Posted on Aug 03, 2008
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
Posted on Jun 03, 2009
Panasonic DMR-XW300. Have been away for 7 months all power off worked perfectly the first day next day sound only no picture.Is it worth fixing or do I buy a new one.
DMR-XW300? sounds like a late 2011 model; either way it's more than 5 years old.
I have 2 DMR-XW390GLX units bought new in 2012-13 - still working today. Even the HDD's in them are still perfect - but that's just pure luck and they're over 5 years old as well.
I'd recommend you replace the unit with a new one of similar brand - with a bigger HDD (e.g. 1 or 2 TB), Blu-Ray/DVD recorder, and all the features your existing suspected faulty model has.
The cost of repairs is usually greater than the price of a brand new unit in the box. Besides which, some service workshops charge a fortune and often leave customers without their products for several weeks or even months. Delays like those are generally not welcomed by many people. No one likes waiting a long time for a result.
5 years is the typical expected lifespan cutoff point for most modern manufactured items; fortunately extended warranty plans may be offered for some models/brands. Nothing lasts forever (though we wish it did).
I do suggest you put the faulty unit aside for now - especially if it has a working HDD in it.
I shall leave this one up to you.
Feb 14, 2018 | Panasonic Televison & Video
Machine keeps putting msg HDD error has occured. Please disconnect the AC mains lead & reconnect it, then press POWER to restart. I have done this many, many times.It just keeps showing above msg.
take it to a computer repair shop for a diagnosis of the problem , but the message is specific
the hdd is failing
if that is the case replace it with a SSHD which has no moving parts or disc
Feb 03, 2017 | Power Computers & Internet
After A.C. power failures, my Panasonic DMR-EH55 does not come "to life" again (even in "off mode"). Removing it from the power for several days then trying again (and repeating this if...
Possible that the main power supply has failed and so it is important that with your skills you must be able to check the power to the SMPS - switch mode power supply.
If power is good then the processor must be checked or there is failure on the motherboard.
Check this link;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 03, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hello! I have a problem with a Panasonic DMR-ES15 DVD recorder. I have an error code E61. I tried all the solutions manual but did not work. I can not use it either as player or as a recorder. reset have a...
Hello.
I had a similar problem with my DMR-ES15 a little over 2 years ago, and, I too, could not find a solution. I resorted to sending it off to Panasonic for their 'out of warrantee' repair, for a hefty price. (I could have bought new, but really liked the features of the ES15.) Panasonic repaired it, and it worked well for another 2 years. Just recently, 3 weeks ago, it died it's second death, with the same issue. I wish I had a solution for both of us, but it seems it is a failure which cannot be repaired by the consumer. I had seen a previous post, which has a suggestion of looking for '2 failed capacitors', but no other information, not even where these capacitors are located in the machine. I enterd a post myself, but have received so solutions/suggestions, and I don't even see my post on this site anymore. I'm a little disappointed with 'Fixya'...
If I find any new information, I'll be sure to post it.
Feb 03, 2011 | Panasonic DMRES15 DVD Recorder
Lenovo netbook disk error
Pretty poor customer service of the repair shop if it failed so soon and they won't honor it. The new drive they installed should have been warrantied, and should be eligible for replacement.
HDD failures in laptops are common in heavy use due them being bounced around a bit. It only really takes one well timed smack to end a hard drives life. They are mechanical, and very delicate. To avoid this, have the next hard drive installed be a solid state hard drive, they are not mechanically, basically a giant flash memory (thumb drive) drive. While they can be a bit pricey per GB, see how much you really need, it will be worth the investment. The newest generation, single-level cell (SLC) solid state drives, are also much faster than standard notebook drives.
Hope that helps.
Oct 05, 2009 | Lenovo IdeaPad S10-1208Uw Netbook
Dell latitude e6400 hard drive failures - is this a trend? I've had 2 out of 3 hard drives in 3 e6400 laptops purchased at the same time about 6 months ago.
have you tested the hdd? i believed dell system has quick test for ram and hdd. try this one, turn off system, press and hold on the Fn key then press once the power button while holding the Fn key. a quick test will appear to check the integrity of the hdd. if the hdd failure after the dell logo then like msgs such as no device found just try to reseat the hdd. this will not void your warranty since the hdd is a customer replaceable unit according to dell terms.
Sep 28, 2009 | Dell Latitude E6400 Notebook
Dmr ez25eb
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Replacing the HDD
hellow
before you replace your hdd ,,
step1. format the new hdd on the pc FAT system
step 2 . set the player 2 default set then replace the hdd..
reply this post when not work
Apr 20, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Problem about turning on
Hi, seems that the ribbon cable, which connects HDD & DVD & video-processing card isn't properly fixed to the stripe contactors. If one of both drives isn't connected, ( even on some contacts only) the other doesn't work, resulting in the described fault. The unit won't boot up.
Had this fault atime ago and had to push the ribbons a little harder into the connector and glued it.
Works since then about a year or so.
By the way, I have a 80 Gb replace-HDD, different brand, as the original one failed. NO problems at all, just louder than before, as it isn't the superquiet Maxtor.
If you try to read the unmounted HDD in a PC, the filesystem is changed or disturbed, resulting in the need to FORMAT, when putting it back into the Pana. Done this just by curiosity, all videos gone then. Even with a HDD, that works properly in the Pana.
Alka
Oct 19, 2007 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-HS2 DVD Recorder Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
