Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
Pilot going out
I have a VN2800BT Vanguard heater and the pilot will light and then when i release the knob the pilot goes out. I have already replaced the thermacoupler and that did not fix the problem.
I'm having same problem with two, so cleaning them again, this time with duster. Will let you know if it works.
Posted on Nov 17, 2009
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Step by step instructions on how to start my heater
The correct order for lighting is:1)turn the valve to pilot. 2)hold the knob down and push the ignitor. It should light the pilot light 3) keep holding the button down for 15 to 30 seconds. 4)when you release the button, the pilot light should stay lit. If so, turn the knob to the desired setting.
Jan 29, 2010 | Vanguard International Infra Red - Medium...
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
215 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
