Question about Logitech X-240 Computer Speakers
Speaker noise logitech 240 makes noises when pc is processing
  • 8 Answers
Logitech X-240 seems love to pickup all RF noise.
Any AM [amplitude modulation] over such RF gets into audio as another noise - some might pick up AM radio signal although won't sound clear at all with some amplifiers [I am serious] - which has high gain preamps - less shielding and unmanaged ground wire handling.
Re-engineer with shilded cable - and [I don't know how normal users will do] - make sure the docking part is not the RF picker.
Well, when your CPU is processing millions of transistors are switching, and we call that digital noise, usually systems with high SNR {signal to noise ratio} should be more immune to such.
One more thing, it could be just the audio card [be it plugged in PCI bus or in Motherboard] could be a bad one - which is picking up noise - rearrange all cables inside CPU box - and check.
Isolate the problem - if it is from CPU, and audio-card --> audio line-out amp chip is picking the noise, - unplud the card or swap with another good audio card, possibly different make/model.
If the audio is on motherboard - do disable through BIOS setup.
Posted on Dec 17, 2008
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Cracking and poping
Check all cable connections, make sure they're plugged in good and tight. If the noise happens when adjusting a volume knob, there is an aerosol spray sold at radio shack that will silence this problem. Otherwise, your speaker(s) may be blown.
Apr 05, 2011 | Logitech X-240 Computer Speakers
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
I plugged the speakers in but it keeps making noises
Just remove the speaker pin that you inserted in pc and plug in again.
Aug 31, 2009 | Logitech R-10 Computer Speakers
Radio station broadcast through speakers
First off no offence but this is happening because they are cheap .. (i know from experience lol)
okay this sounds dumb but it works radio waves cannot go through brass so setting something brass by your speakers will solve this problem
Please Rate Me
May 28, 2009 | Logitech X-240 Computer Speakers
Humming Noise from satellite speakers
noise can be generated since dust in the jack connector of your PC, bad sound card or belive or not, the socket. try to unplug another devices and leave alone the x240... compare.
Apr 02, 2009 | Logitech X-240 Computer Speakers
My computer speakers are picking up radio stations with out me do
define the noise you are getting.... computers are horrible for radiating radio interference .... so solving it may jus be a case of moving the speakers further away from the computer if possible
Mar 22, 2009 | Logitech X-240 Computer Speakers
Logitech x-240 speakers
Try to unplug everything, re-install drivers and see what happens.
Jan 18, 2009 | Logitech X-240 Computer Speakers
Interference?
You must use a UPS on your PC set.
Jun 24, 2008 | Logitech X-240 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Logitech X-240 Computer Speakers Logo
274 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
