I need a CPU fan for a 8480-25x IBM server - Computers & Internet
  • 48 Answers
These fans are all very generic, just measure the size usually in mm and jump on any computer website such as newegg.com and buy one.
Goodluck.
Posted on Dec 17, 2008
Cpu fan error
Well it usally means the fan is bad it may work and keep your CPU cool but it can still send the code just replace the fan
Oct 25, 2013 | IBM xSeries Computers & Internet
IBMx3650 amber light appears , error indicates CPU
Most probably this would be Motherboard issue. Rare cases for processor fault. Easy to find out if server works on dual processor
Trouble shooting:
1: Perform Power Cycle (Turn off server, remove power cord from server and wait 15 min)
2: Try with minimum configuration (1 cpu, 2 ram )
(swap CPU if have dual)
3: Perform IMM update
If issue remains, replace motherboard and see if it solves issue.
Oct 21, 2013 | IBM x3650 Server
BUT AFTER TURN ON IT ABLE TO WORK FOR A SHORT TIME AND TURN OFF AGAIN PLEASE HELP
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 22, 2013 | IBM x3400 Server
Ibm eserver xseries 205 no display
You probably don't have a high enough wattage power supply to support the graphics card. Usually you need at least 300-350W
Jan 27, 2013 | IBM eserver xSeries 205 8480
I have one server IBM X series 346, which is giving Fan alarm , its fan LED showing amber, though server is working fine.
The problem could be a faulty CPU fan or the fan and heat sinl assembly is clogged with dust.
Check the fan, if it does not spin freely then replace the fan. If the fan and heat sink is clogged with dust, remove the dust and use a can of compressed air to clear the dust from the heat sink fins.
Apr 07, 2011 | IBM xSeries 346 Server
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
IBM fan error
I have updated all the firmware of the server using latest updates
and after restar it work properlly . waw my problem solved.
Dec 30, 2009 | IBM x3400 Server
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
IBM RISC 6000 Error code
POWER supply failed or FAN failure 888-103-409-094
Aug 30, 2007 | IBM RS/6000 7013 (57FTOJ50) Server
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
