Question about Dell 3100MP Multimedia Projector
Dell 3100MP Projector - No Signal Check Cable
Projector starts up and shows DELL logo, but then goes to a blue screen and says "No Signal - Check Video Cable". I have tried replacing the cable with a new one and also tried connecting it to different PCs. Is there anything else I can try other than a repair shop?
  • tgaulin Jan 05, 2009
    Tried that. But thanks anyway.
  • lebanonva Feb 09, 2009
    no signal when connected to a mac. works fine when connected to PC
I think I had a similar problem- are you connecting to the right socket.? The VGA on the 3100MP socket is `VGA out` you might need to connect to the `DVI monitor in` socket ,possibly needing a male DVI connector that connects to a male VGA lead.(Maplins , if you are in UK ,sell one for about £10)
Posted on Jan 05, 2009
    President:
  • 2,992 Answers
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Posted on Dec 17, 2008
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
May 28, 2017 | BenQ PB6100 Multimedia Projector
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 21, 2011 | Dell 3100MP Multimedia Projector
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
I have 5 Dell 4310 WX projecors and I would like to display my logo when they start-up. Can this be done with the projector only or is a laptop necessary for this to happen?
I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
Jan 14, 2010 | Compaq Presario M2000 Notebook
Dell 3400mp not getting signal from Macbook
If you were using the Apple S-video adapter to connect to your Dell projector, please realize that MacBook models with NVIDIA graphics cards do not support this adapter. Otherwise, please be more specific about what model Mac you have and what adapter cable you are using.
Aug 24, 2009 | Apple MacBook Pro Notebook
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
No Sound
check the setting of sound.. if its okay check the speaker wire connector or the chips.. but be care full for opening if you can open and fix no problem..
or look qualified technician for projector
Feb 03, 2009 | Dell 3100MP Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Dell 3100MP Multimedia Projector Logo
978 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
