Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3t that fills with water when not in use
I have drained it using the drain/spin option but it has filled again it is dripping from the little (vent?) located at 10 o'clock inside the door jamb
  • 61 Answers
Sounds like you have a bad fill valve it should only let water into the machine when the fill valve is energized. If water is coming in when unit is not in use change the valve.
Posted on Dec 18, 2008
Kenmore Elite HE 3t motor runs but does't spin or drain
SOUNDS LIKE BAD CLUTCH OR MOTOR COUPLER IF ITS BELT DRIVEN MAY HAVE BAD BELT OR LOOSE BELT. i DOUBT ITS IN UR DRAIN PUMP AS UR NOT GETTING A SPIN WHICH IS WHY NO DRAIN.
Oct 17, 2014 | Kenmore Washing Machines
Washer won't drain water
Open then front panel and see if you need to order a water pump mine has a A nail on water pump repair clince.com hope that work or go to youtube type washer don't spin
Nov 07, 2013 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
191 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
