FixYa.com
Tags:
Canon EOS-20D Body only Digital Camera
Problems detecting charged battery packs
posted by raespoon on Mar 25, 2007
my 20d camera, after about a dozen shots, displays the dead battery signal. i have to disconnect the grip, blow into the battery chamber, and reconnect it. of course, to only have it happen again after another dozen shots. it has crippled my efforts with candid shots. help! ...and thanks ahead of time for anyone who has the solution.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 26, 2007
Thanks for Trying (70)
bike guy
Rank:Guru Guru
Rating: 85%, 124 votes
I assume that you are using a Canon battery. I wonder what blowing into the battery chamber does? My thought is that a connector is loose or a component is overheating. Either way, I would strongly suggest that you take your camera to your nearest Canon Digital repair shop. I do hoope it is still under warranty.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 15, 2008
Not Rated (0)
PaulMo
Rank:Wiz Wiz
Rating: 82%, 111 votes
I have not used the camera grip attachment, but I get about 4 hours of operation with the normal internal battery - I use a Duracell DRC511.
Can you Help with these Digital Cameras problems?
Err 99
Error code 99 has developed on... Answer This...
shutter release button problum
i press the shuttwer release... Answer This...
INTERNAL FLASH NOT WORKING
I attached a Macro Ring to the... Answer This...
20D flash
The metal "bracket"... Answer This...
EOS20D won't turn off, take...
Very odd- This just happened... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
