Question about Orion1934 19" TV
We have an orion model 1934 tv and can only pick up a few channels on it-less than 12 and it is hooked to our cable which has 70 channels access. this is a 2002 year make so i think it should pick up a lot more channels thanks for your help--richard
  • lizscott2007 Jan 11, 2009
    same problem but cant access menu with universal remote
  • Anonymous Jan 31, 2009
    I have the Orior 1934 TV (May 2002) and can only pick up a few channels with cable hookup.
  • Orion Master
  • 520 Answers
If you can, go into the ch set menu and change it from tv to catv(cable). then run the auto ch memory. I hope this helps. Orion's free help line is 800 289 0980.
Posted on Dec 19, 2008
How can I hook up a Magnavox dv220mw9a DVD/CD player to my Orion 1934 19" TV?
One possible solution would be to use an RF Modulator. This will convert the composite (red white and yellow jacks) output from your player to channel 3 or 4 on your tv. Try radio shack or any store that sells electronics to find one. Follow the instructions that come with the RF Modulator.
I hope this is helpful.
Bobya.
Jan 05, 2011 | Orion1934 19" TV
I have a 19'' older (approx 1999) Sharp tube TV that won't show the cable channels even though the cable is hooked up to the tv (the cable has been tested with another TV and works perfectly). There is no...
Even with the TV in the wrong mode, you should be able to see some channels lower than 12. Try that first and report here what you see. If you can get a few in that range (2-12) but nothing else, then the TV is in broadcast mode not cable. You will need to change it to cable mode to get the remaining channels. You should be able to locate a universal remote for $5 or so that will allow you to get into the menus.
Dan
Jun 18, 2009 | Sharp Televison & Video
Have extended basic cable-all the channels not showing
Cable co. can place stations at any # they wish... my antenna CH3 is carried on 252. I have to have a CH guide to keep-up.
Feb 12, 2009 | Orion1934 19" TV
1934 model recieving
cthy_prry,
The IR detector is in your TV set. It is the device that picks up or captures the IR signal from your remote control and turns it into an electrical signal that the TV via a processor interprets as a function or command to have the TV perform in a certain way as turning on, channel up or down, volume up or down, etc.
IR means Infrared
I hope this answers your question.
Thank you,
Shuttle83
Aug 19, 2008 | Orion1934 19" TV
Many channels do not come in. I feel it needs reprograming. I have cable .
Make sure that the set is in the correct mode. It sounds like the set is expecting TV signals from an antenna rather than cable. The cable channel assignments are different. Place the set into CABLE mode and autoprogram the set. That should resolve the problem.
Dan
Jul 07, 2008 | Orion1934 19" TV
Orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Jun 13, 2008 | Orion Televison & Video
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
143 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
