Running windows xp.local area connection says network cable unplugged.Thats not the case,all cables connected. local area connection 2 says limited or no connectivity
  • 68 Answers
On local area connection 2, right click and goto properties. Now scroll down to the 'internet protocol version 4' or 'tcp/ip' and click properties again.
Make sure that everything is set to automatic if it is not. If you have a router than the router may refuse a connection attempt from your PC if it is not setup to assign DHCP address. If this is the case then you will have to setup a address manually.
Posted on Dec 17, 2008
My tablet pc, came without wifi mac address, so it doesnt have wifi but it does have internet using the cable
You should be able to purchase the necessary cable from your local computer store to connect your tablet to your router. Of course you will then be limited to being able to use your tablet only as far from your router as the length of the cable. There should be a way for you to find out the MAC address for your WiFi depending on which version of Windows you are using.
If you are using XP:
1) Go to your Start button, click on Run.., and when the command window opens type 'ipconfig /all' into the window.
2) The system will list all of the network adapters present on the tablet, and below the name of the adapter will be a line headed with Physical Address. This will be your MAC Address.
If you are using Vista
1) Follow the instructions above that were given for XP, and again when you look at the Physical Address you will see your MAC Address.
If you are using Windows 7:
1) Open the Network and Sharing Center > Local Area Connection > Details > Physical Address. You will want to make sure that the Local Area Connection you choose will be the built in WiFi of your tablet.
2) A box will open up with details on your Network connections, and the third item down will be the Physical Address.
Take the Physical Address information that you have received from the correct sequence above, and use it in your Router Setup to allow your tablet to connect using WiFi.
May 15, 2011 | Computers & Internet
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
Limited or no conenctivity using the local area network
run cmd, type in the command prompt window " netsch winsock reset "
automaitcally teh dhcp will be reseted... then type again on command prompt window " registerdns " then rebooted pc and test internet connection..
Jan 14, 2010 | Arris SURFboard SB5101 Cable Modem
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
Rt164 reset button does not work to default
Hi friend
I hope it will work for you,please follow the steps:
1) Give the router power,then with a pen press the reset button for 10 secs,after that unplug the power cable from the router for 10 secs and wait
2) After 10 secs plug the power cable back,and press the reset button for another 10 secs,after that unplug the power cable again for 10 secs. and wait.
3) After 10secs plug the power cable back and press the reset button for 10 secs, after that unplug the power cable again for 10 secs and wait.
It will bring the router back to default settings.
now if your ethernet ports have limited connectivity,please follow the steps:
If you have windows XP try this
1) connect the computer with a wire to the router
2) click start menu>contrlo panel>to your left you will see switch to classic view,click that
3) Double click and open the icon named network connection
4) right click the icon named local area network connection,click properties
5) Now click the tab named "configure" under the general tab
6) Click the tab named "Advanced"
7) Under that tab you will see something named "Property"
8) Inside that white box you will see either "Speed/Duplex" or "Link Speed/Duplex", select that
9) To your right just beside property you will see 10 mbps half duplex,select that and click OK
10)Click Ok if you find any or click Close,whicever is there.
Restart the computer and enjoy working without any limited connectivity.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Computers & Internet
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
                      or
                                         (OR)
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
No connectivity after.....
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
