Question about D-Link DI 514 Wireless Router (DI-514)
Stop neigbour from using my network. Speed has become slow
I have a D-link Di 624 hard wired from my neigbour 1 to mine as he has high speed and i can't get it from the same provider. My other neigbours cannot either. We are suspecting that neigbour 2 is using band width from me as he is pretty close to my house and on the other side.
Can i prove that somehow and how to i turn neigbour 2 off
  • 40 Answers
Password protect your connection, if you are using Internet sharing option, limit the number of connections to 2 (one for you and the other for your neighbor no. 1)
Posted on Dec 17, 2008
Speed on Verizon Fios
I had this problem or similar. Verizon (in New England area) upgraded my speed to 7MPS Download and 1MBS upload. It was slower than the old speed. I called in Verizon and after a lot of back and forth - well, to be fair, they were good - it turns out that the router on their site was old. They unplugged us from it and put us on a newer faster router and Voila! Worth a shot.
Jan 20, 2014 | D-Link AirPlus Xtreme G DI-624 Wireless...
My net speed get very slow
If you are talking about about your speed while connected to the wireless, I do believe this is a 801.11b, which means it is a slower router (for wireless) and only goes up to 11Mbps. If you think you are getting even slower speed than that, log in to it, go to the wireless setting tab and find the setting for the connection speed. make sure its set to use the full 11Mbps! (sometimes is can be set to only 1-3 or 3-5Mbps).
If you are talking about the speed while connected via hard wire (eithernet cable), log in to your router and make sure that the wired speed is set to the highest value (I believe this one goes to 100Mbps full-duplex) and also make sure that the cable you are using is at least a CAT5 or above (CAT5. CAT5E, CAT6). A CAT3 ethernet cable will not go up to the 100mpbs! (this is printed on the wire).. also make sure that the port on your computer also goes up to 100mbps!
hope this helps!
Jan 16, 2011 | D-Link DI 514 Wireless Router (DI-514)
Weak signal
Where are you measuring the speed:
* transferring files from one computer on your network
to another computer on your network?
* using a "speed-test" web-site (http://speedtest.shaw.ca) that reports the speed?
What level of service are you paying your ISP for? "Lite"? "High-Speed"? "Extreme" ? "Nitro" ?
The "bottleneck" could be between your ISP and your router,
not between your router and your computer.
Dec 13, 2009 | D-Link AirPlus DI-524 Wireless Router
I use the D-Link DI-704p router for an ethernet Lan with 8 Macs. Fast in the morning, horribly slow up/downloads in afternoon. Output runs at half speed of input from provider when tested in afternoon.
access your router with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi advanced then check signal channel type 4 , 6, 11 are working fine try 1 by 1 theses channel then check.
Set channel which give most high speed.
When you set channel always save settings then restart computer and router both after save settings then check.
Thanks for using fixya.
Jul 28, 2009 | D-Link DI-704P Router
My D-Link Xtreme G DI-624 worked quite well for 5 days -- then failed to connect with Internet while I was using it 2 nights ago. "Network Connection Disabled" was the message. Can you tell me which cables...
From modem's ethernet, connect the wire to the router's Internet/WAN port. From your PC, connect the wire to port 1 of the router. If it says network connection is disabled, right click on Local Area Connection and click on Enable.
Jun 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
79 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
