Heater using more electricity then normal?
Hi I have an older model dimplex storage heater in our apartment. We have two, a medium sized one in the living room and smaller one in the bedroom. When we flick the heaters on at the wall the orange light comes on and does not turn off the entire time. According to other people with storage heaters the orange light should only be turning on during the night when our nightsaver electricity kicks in. We also have the heater turned to ''evening boost.'' We just got a two month electricity bill for 420euros. We live in a small one bedroom apartment, and the bill seems way to expensive. Unfortunaltly no owners manuel was left in the apartment for the heater so I can not see if the orange light at the wall is normal. I know you are supposed to leave the heaters on all day with a timer for the boost, but they seem to be eating electricity. I thought the purpose of storage heaters was to save you on electricity by only using it during the cheaper periods. I want to know if the light on the wall is signifying that the heater is giving a constant boost 24 hours. Please help
4 Suggested Answers
SOURCE: Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Posted on May 26, 2008
SOURCE: My on switch is lit up red all the time
Hell Yes, my electric bill was 200.00 ave. a month last yr
Posted on Dec 17, 2008
  • 3074 Answers
SOURCE: want to heat electric storage
set the timer a 180 for it will come on at night, instead of day
Posted on May 06, 2011
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
Can i use a normal 13amp plug on a dimplex plx1500 panel heater
Probably not the best idea. It may overheat when the heater is running at the high setting. Best to use a 15A rated cord and plug.
Nov 01, 2011 | Dimplex Compact Electric Flame Stove...
Hi I have a night store heater model 79168 in my new home and no idea how to use it!! Please help :)
Here is a good article for Dimplex, a storage heater manufacturer, that explains the the theory and how it works. I'm sure you will find it interesting. http://www.dimplex.com/storage_heaters#
Basically, thermal storage heaters heat ceramic bricks during off peak hours (during the night), store the heat to be used during peak hours (during the daylight hours), when electricity is more expensive per kilowatt hour.
Hope this helps you.
Apr 18, 2011 | Heating & Cooling
We have Dimplex XLS storeage Heaters and no operating Instructions. Our electricity bill is very high so we must be doing something wrong. Can you help
Not sure if this is the model of your storage heater but it may help
http://www.storageheater.co.uk/Manuals/Dimplex/XLSN%20Operating%20Instructions.pdf
Feb 11, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Does my FCXA/FCX24A electric storage heater contain asbestos? The number on is 00401706WW...
The use of asbestos in insulation and sprayed-on coatings was banned in 1985. I believe your heater is newer than that, so probably not.
Dec 16, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Mar 07, 2009 | Dimplex DS5598 Mid-Size Heater
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Dec 17, 2008 | Dimplex DS5603 Heater
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
