Question about Geovision GV650-8 GV-650-8 GV 650-8 60FPS 8 CH. PCI DVR (DM6010)
Camera pictures are jumping arroung on the geovision screen.
Cameras are jumping arround very fast to a different camera spot. what do you think is causing the problem I am using GV650 with 8.2 software version and win Vista
Thanks
    Problem Solver:
  • 15 Answers
Try calling up the system on the 16 screen to see id if thy still jump around if not and its only on the single screen then u have the camera rotation on wich u can turn off. its at the bottom on the right it looks like a monitor with arrows pointing to the right
Posted on Mar 29, 2010
Why is my screen red on 4 cameras?
This is usually caused by logmein or some other similar program. You can restart Geovision and it goes away or you can try disabling logmein. The good thing is that the cameras are still recording properly even though live view looks like that.
Jun 16, 2014 | Geovision Home Security
Spots on the display screen
Still not clear, what you mean. But take care wham cleaning a lens. Never use a fluid like alcohol. Use a special lens pen or the soft brush on the other side of a lens pen, when you think the lens is dirty. Spots, or disk, also can appear when light is entering the lens from an angle. Even the expensive Fuji X10, had orbs or disks on the pictures in certain situations. Like dark with one or a few sharp lights close bye. Try the camera in different situations, to make sure the phenomena is in the camera or just a strange rare occasion.
When it is caused by a defect in the camera, it should show on every picture.
Dec 26, 2013 | Vtech Kidizoom Digital Camera
GeoVision NVR Software for 3rd Party IP Cameras
Not exactly sure of the question but Geovision does allow for many 3rd party IP cameras to be connected. Check the Geovision website for a full compatibility list. I have personally worked with Hikvision and Vivotek with no issues. You will need to purchase and install a dongle. The dongle comes with software that you will need to install before using the USB dongle. The dongles come in 1, 2, 4, 8 & 16 camera capabilities. There is usually no cost difference to buy two 2 camera dongles or one 4 channel dongle. So get whatever you need. Just be aware that is will look odd having 4 USB sticks protruding from your NVR. There are also some internal dongle options that connect directly to the motherboard.
Oct 10, 2013 | Geovision 32 Channel NVR Software License...
Have geovision gv-600, the video lost on 5 out of 10 cameras?
If you confirm this is the card and not the cameras, then you may have some bad ports. You may need a new card. It happened to me at a customer after a lightning strike. Although mine was 4 cameras (1-2-3-4). You can also verify that the cameras are activated on those channels. That would be the easy fix.
Apr 11, 2013 | Geovision GV-600-16 Digital Video Capture...
Will the GV-FE110 Fisheye IP Camera need the Capture Card?
No. None of the IP cameras require a capture card. Instead the included Geovision software can be used to record the video. That's the beauty of Geovision. Good software at no cost when you use their cameras.
Jul 20, 2011 | Geovision Gvfe110 13 H264 Fisheye Ip...
GeoVision GV-BX110D cameras unexplainably changing from color to black & white. Geovision NVR
This has to be caused by either a setting in the camera or the light level. If this is not the case, you probably need to RMA the camera. This is not normal unless the aperature is set wrong.
Jun 02, 2011 | Geovision NVR Lite Box Camera System 4 X...
I have a Geovision GV800 8.3.2, 16 channels and have 4 cameras installed. I tried to add 3 more cameras but they don't appear on screen, just on the Camera Record Setting, where the recording is ok. I've...
Hello
Have you tried at "Camera/Audio Instal" Menu?
Click the Configure button and select Camera / Audio Install to bring up the dialog box:
Click the Activate button and specify the cameras to be viewed
Hope that help.
Jan 09, 2011 | Geovision GV-800-16 Video Capture
Spot that shows up in the same spot on all my pictures
It can be a piece of sticky dust or dirt on sensor surface which can't be removed with a blower or canned air. You can try to remove it by yourself with special cleaning swab and cleaning liquid. But this process requires some experience, so the safer way is to bring camera to service center where sensor can be cleaned fast and risk free.
Jul 19, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Geovision play back has blank blue screen every few seconds lasting aprox 1 sec. Put all cameras on power "regulator". any other ideas?
I have the same problem and I'm looking right now the answer. I think that windows 64bits its the problem
Mar 29, 2009 | Geovision GV-800-16 Video Capture
Digital Camera produces spots on screen Not caused by dust etc.
If in camera monitor and picture the same the camera or card has problem try to down load other computer check still the same
Oct 24, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Geovision GV650-8 GV-650-8 GV 650-8 60FPS 8 CH. PCI DVR (DM6010) Logo
430 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
