Question about LG 42PC3D 42 in. Plasma Television
Tv clicking on and off
I replaced the main board on my 42 inch plasma tv and it is still clicking
    Novelist:
  • 152 Answers
Hello, you need to check your service manual for voltage testing on the power board. it will tells you what test point to check and what panel tp adjust. you may need to adjust the voltages by using a dmm and adjusting the vs/va/vy
this is recomended after exchanging pcb boards,
service manual info looks like this on a lg service manual
CHASSIS : RF-02RA
MODEL : MT-42PZ40/V/B/R/S
MODEL : MT-42PZ41/V/B/R/S/VB
MODEL : MT/MZ-42PZ42/V/B/R/S
MODEL : MT/MZ-42PZ43/V/B/R/S/VS
(1) Va Adjusment
¤ Connect pin 1 of CN209 to (+) jack of D.M.M.
¤ŁAfter turning the VR402(Va ADJ), voltage of D.M.M
adjustment as same as Va voltage which on label of
panel right/top.(Deviation : ±0.5V)
(2) Vs Adjustment
¤ Connect pin 8 of CN207 to (+) jack of D.M.M.
¤ŁAfter turning the VR401(Vs ADJ), voltage of D.M.M
adjust as same as Vs voltage which indicated on label
of panel right/top.(Deviation : ±0.5V)
(3) -Vy Adjustment
¤ Connect pin 5 of CN208 to (+) jack of D.M.M.
¤ŁAfter turning the VR403(-Vy ADJ), voltage of D.M.M
adjust as same as -Vy voltage which indicated on label
(4) Vsetup Adjustment
¤ Connect pin 1 of CN208 to (+) jack of D.M.M.
¤ŁAfter turning the VR404(Vsetup ADJ), voltage of D.M.M
adjust as same as Vsetup voltage which indicated on
label of panel right/top.(Deviation : ±0.5V)
[ Refer to Typical Voltage
1. Va : 30 ~ 50V
2. Vs : 170 ~ 185V
3. -Vy : -60 ~ -90V
4. Vsetup : 210 ~ 240V
[ Replace PDP Module or Power Board, adjust certainly Power
PCB Assy Voltage.
hope this helps good luck with you tv repair
Posted on Dec 22, 2008
    President:
  • 2,110 Answers
It can be fixed by replacing the ZSUS terminal board...
If u can't then contact technician...
    Master:
  • 474 Answers
Your not pluggin the T.V. into a power strip and then into the wall are you?
The clicking may be the surge protector resetting because of to much power being connected into one outlet.
The T.V. probably has a built in one and it keeps going off.
Try plugging the T.V. by itself, into a wall plug with nothing else and see if it works then.
Posted on Dec 17, 2008
    Master:
  • 416 Answers
It sounds like the standby supply is running the main power relay, but the set is not starting up. The primary supply or horizontal output transistor might be at fault. If its power supply it can be like in safety mode it is switching the set off when it senses a faulty circuit trying to draw more than its share of current. When it switches off it can`t see the fault anymore so switches back on for another look etc. You would need to take the set to a professional repair center to have it diagnosed, or repaired. Good Luck
    Sergeant:
    Novelist:
  • 327 Answers
The connections you made on the new main board are not proper as it getting short in between so check out for that.it will solve the problem.
    Genius:
  • 1,199 Answers
This sounds like you need to replace transformer!
    Novelist:
  • 59 Answers
Hi headikej,
It sounds as though the problem is not with the board, but rather with the transmission of power to the board. As odd as this may sound, there may simply be a faulty power cord or a loose or faulty wire where the power reaches the board. I admit that these are difficult to test in isolation (unless you have extra parts lying around), but since I'm assuming your TV is no longer under warranty (since you replaced the board yourself), it's a lot less expensive to get the extra wires and test them before you take it to be serviced by someone else.
In an effort to save time and money, I suggest examining the path along with the power travels - from the wall to the board inside the TV. Look at all the wires with a magnifying glass - if you see any exposed, melted, or discolored wire, there's a good chance that it's your culprit. Also check the contacts of the wires if possible. If you see any rust, dip the contact in Coca-Cola and wipe it off with a dry paper towel. If there's on rust, one of the contacts cold have simply lost its electrolytic properties with age - that's when you replace the wire (if you can discern which one).
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
  • Lorne Dechtenberg
    Lorne Dechtenberg Dec 18, 2008
    Ginko makes a good point - the clicking is not directly due to the loose or damaged connection. Rather, it is a controlled response by the main board in order to prevent a fire (which could happen if a resistor fails - the amount of power passing through a circuit would then exceed the wire's safe limit).
    There's also one other possibility: the problem could be in the power supply itself - if one or more of the of the components in the power supply has stopped working properly (for example, a capacitor building up too much current, or a short circuit near one of the diodes), you may need to replace the power supply. It's not a cheap part (almost $100), but it's a lot less expensive than taking the TV to be serviced. Here's a link to one of the many places you can order the correct model power supply:
    http://www.shopjimmy.com/showparts.cfm?i...
    Again, I hope this helps, and let me know if I can be of any further help.
  • 112 Answers
Hello sir
thanks for asking us sir try to resold all stches
and on it
i hope your problem solved
  • 275 Answers
For support for your LG product go here: http://us.lgservice.com/index_b2c.jsp
this link will direct you to the manufacturer's website for support and service information
  • 153 Answers
Check with the power supply the switchimg on and off may be because of non proper power supply
  • LG Master
  • 19,396 Answers
How did you know the mainboard was faulty?
There can be a dafective ysus or zsus board for example, or a bad power supply.
Tell me if the tv blinks a number of times of if there is an error message.
  • Ginko
    Ginko Dec 17, 2008
    The clicking is because the TV is on protect mode.
    This is when TV detects a fault and the mainboard activates a safety switch to prevent further damage.
    As I told you frequent faults concern the PSU board and the sustain boards, there are also few more boards that can be defective. All components must be tested before you replace one.
Hi , was watching my 42 inch VIORE Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
Dec 22, 2017 | Toymax Viore 42 in. Plasma TV
My samsung 42 inch lcd tv won't turn on, it makes the click as if it's going to turn on but then clicks again as if it's switching off
This has bad capacitors on the main power board, easy to replace if you can solder, the capacitors will bulge slightly on the top if they are no good. You may find that between 1 and 4 of them will need replacing however they only cost about a pound each
Jan 24, 2011 | Samsung PS42P2S 42 in. Plasma Television
LG 42 inch plasma. Half screen is ok (rh side) other side black
Buffer boards or Y-SUS main needs to be replaced. What do you mean by motherboard? The power supply board or the Logic or X main.... They YBU/YBL and the YSUS work in unison. Y-Buffer upper controls top half, Y Buffer lower control bottom have YSUS controls both of those. There is also D, G, E F boards that can split screan. But they to are controlled with the Y-SUS Main. Hope this helps...
Jun 29, 2010 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
My tv won't turn on, the red light just blinks and
power suppy needs replacing...according to samsung and other forums i read when mine did this its a common problem
Feb 09, 2010 | Samsung HP-R4262 42 in. Plasma Television
I have a 42 inch vizio plasma t.v. and I have power but no sound or picture, I've unplugged it all night and still doesn't work! It's
For the 42" plasma, you need to change your sustainer boards or your main board to fix the problem. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
For the L42 HDTV, you need to change the inverter boards or the main board. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
Jan 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
42 inch techwood plasma no picture
the most common cause for this is the capacitor (1uf 630vdc)located at c19 on the main power board.the cost for this component is around 90p
Dec 17, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
LG 42PC3D 42 in. Plasma Television Logo
67 people viewed this question
Computer Repairing
Computer Repairing
