I had a Panasonic bath fan installed the week before Thanksgiving. It was represented that this fan was virtually silent. It is however, noisier than the 22-year old fan it replaced. My contractor tells me that the problem is that the vent exiting the fan is vented by a 3" (too small) flexible hose that travels into the ceiling and ties into a larger duct that isn't reachable. Panasonic fans are at their best when they have a 4" vent hose that travels with a minimum of bends for a total length of 20 feet. Any conditions other than that and they get noisier. It was louder than normal when we installed it. We could only reduce the noise by changing the size of the existing hose to 4” and running that all the way to the central air duct for all the units wherever that is. Maybe Mario (building superintendent) knows. This would entail taking down the ceiling. Is there any other solution? Is there another panasonic fan that fits the smaller size vent? This was very expensive with the installation, and I cannot stand the noise.
  • babala Dec 19, 2008
    Babala says this is a vibration noise. Electrician is suggesting motor replacement with a motor that has a lower sone rating.
  • Danny Clark
    Danny Clark May 11, 2010
    What kind of noise is it? Wind noise only?
    Or is it more of a vibration and motor type noise?
  • 334 Answers
Vibration noise is usually due to inballanced, or damaged fan blade.
Take off the coveer, make sure its installed properly, the blade is not cracked, and check for ballanced motor/bracket/blade.
They typically have rubber bushings between the motor mounts and the housing to dampen vibration noise.
Posted on Dec 19, 2008
How often should I bathe my dog?
It is recommended that you bathe your dog at least once every three months. If your dog spends a lot of time outdoors, I would suggest bathing them more frequently.
Aug 15, 2012 | Pets - Others
My asus nvidia geforce en210 silent DDR2 512mb makes my windows 7 to freeze
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Heat is an important factor. Your computer system is getting too hot, the culprit is more than likely the Central Processing Unit.
Clean your computer of all dust pay attention to the CPU cooler and install some fans in your computer system.
120mm fans are quieter than 80mm fans and they provide greater airflow. Install the biggest your chassis can support.
Also see my published guide entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!! as you may need to install the latest drivers for your graphics card.
You may also want to scan your computer for viruses as they are known to overload a computer system bringing it to it's knees.
Fixya offers such services!
Thanking kindly
damnor01
Feb 26, 2011 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
Great nutone bath fan/light. just completed installation and fan makes soft noisy rattle when running. trick for silenting the noise would be great. thanks
if the blades are metal they may have been bent during installation. try to straighten them. make sure blades are not rubbing anything.
Oct 26, 2010 | Broan-NuTone Home
Silen hill 4 The room won't open in Windows 7 Professional 64bit? I Don't get any errors at all. i am goign to look at the event Viewer. but it saysWindows cannot access the specified device, path, or...
The Room does run on Windows 7 64-bit.
I just played a pirate copy of The Room on mine, to make sure a purchase of the proper boxed game is not an unplayable waste.
It worked fine after a minor adjustment to setup.reg and so should the real DVD, if that is what you are using. My version of Windows 7 does not even, to the best of my knowledge, come with the virtual XP.
These are the instructions I followed:
"Hey world's people, if your pc is say: ''Game not installed correct'', Thats why:
-You're using a Windows Vista 64 bit or Seven 64bit
-So just follow the following steps:
1. Click in the setup and install.
2. After setup is over, open Setup.reg with notepad,
3.Replace the line [HKEY_LOCAL_MACHINE\SOFTWARE\Konami\SILENT HILL 4\1.00.000] with [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Konami\SILENT HILL 4\1.00.000]
4.Save
5.Double click the setup.reg file again and click YES!
6.Enjoy!!"
Sep 17, 2010 | Konami Silent Hill 4 for Windows
Some water condensations around bath fan
THATS GONNA HAPPEN WITH THE HUMIDITY IN THE BATHROOM AND THE TEMP DIFFERENCE. TRY INSULATING THE DUCT WORK FOR THE VENT. INSTALL A FLAPPER SIMILAR TO WHAT A CLOTHES DRYER HAS. U DON'T WANT COLD AIR COMING IN. INSTALL A DEHUMIDIFIER.
Dec 12, 2009 | Home
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic phone rings but line is silent and can't make calls
Tossed out the phone and bought a new much better Uniden. All works great now.
Aug 28, 2009 | Panasonic Lands Phones
Video Cam Suite 1.0 does not work with Windows Vista 64 bit
Excuseme If I don't explain so clair, because I don't speak english well, but let me try that I did to solve this problem. First I installed a Virtual Machine(VMware Workstation 6.5.1) in miy Pc(64 bits) . Second, I installed a Windows Vista home basic(32 bits) or Windows XP Sp2 (32bits) on it., depending of what Operative sistem do you have in your real machine. And finally I could installed the Videocam suit in the Virtual Machine and everything was ok. I could transfer all my videos of the camera to the pc very easy The only inconvenient is that you need to transfer the videos downloaded of the virtual machine to the real machine with a flash memory or similar something.
Jun 12, 2009 | Panasonic PV-GS500 Camcorder
Noise
The first Fresh Airs were almost silent, then Jackson switched to a noisier fan. Everyone complained, but... now Jackson's out. He also switched to cheaper LED equip- hence THOSE problems! The Tech people know the problem, they should be able to help. 800-989-2299
Mar 04, 2009 | Ecoquest Fresh Air Air Purifier
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
