Question about Creative Labs I-Trigue 2.1 3300 Computer Speakers
Sound only coming out through one speaker
I started having a problem wit my I-Trigue 2.1 3300 speaker system. I don't know when it started exactly but the sound only comes out through one speaker. The speaker isn't faulty because they both work if I put them into the right speaker slot seperately. If I use the left connection, no sound from either speaker. I guess it has to do with the circuit board in the sub?? I've tried it on two different computers, an Intel Macbook I once had and my Intel iMac. I think it worked properly on both computers. It worked fine for a few years on my PC I no longer own. I'd like to keep these if it's an easy fix... Any help??!!
  • 7 more comments
  • Anonymous Nov 07, 2007
    I've got the exact same problem. Time to buy new speakers.
  • Anonymous Jul 14, 2008
    I have the same problem with my I-Trigue 2.1 3300 speaker system. The sound only comes out through one speaker and the
    right speaker slot separately. If I use the left connection, no sound
    from either speaker. Must be a common problem with these...?
  • staceyk08 Sep 03, 2008
    I think these are the speakers I have... anyway they look just like the picture. My speakers worked at my old place and I moved into a different house . I set them up here and the same thing is happening... Both speakers work when I put them into the same input in the back of the subwoofer, but the sound won't work out of the other input (output?) whatever. Anyway.... I love these speakers and need them fixed! If the speakers work isn't there a way to fix this problem?
  • sterlingv Feb 06, 2009
    Last night both were working fine, now i have the same problem, the right output works and the left doesn't. AND YES the computer is sending audio to left and right equally. Well time to take it apart and see if I can re solder something.
  • dogprotag Feb 07, 2009
    from either speaker so it the left connection that has a problem .
  • Anonymous Mar 12, 2009
    Exact same problem TWICE! The first time it happened about 1 year after purchase at which point they replaced the whole product with a ew one. ! year after that the exact same problem happened but now they wont even reply to emails. Very very poor customer support and definitely an issue with this product. I have tested this extensively including plugging it to other computer and audio sources. The audio line out for the left speaker stops working - simple as that. I have bought a lot of Creative products in the past for personal and business use but I will not be purchasing anything else from them in the future.
  • itruge_broke May 02, 2009
    Same problem here! The left channel from the subwoofer is outputting a signal however I can't hear anything except for "snow". I stored my 1 speaker thinking it blew or something but I just checked it today after about a year and it's working fine in the right channel connection. Any help on this would be appreciated =)
  • bethel95 May 11, 2009
    Just after passing the two-year mark last week with my 3300s, I had the same problem with the left audio channel and also with the subwoofer (bass) channel. Just for fun I opened the subwoofer to examine the amp circuit board--no visible signs of component failure, so I'm guessing that some transistor died "softly." Doesn't look like something even an electronics repair shop could fix, as there are globs of hot glue smeared over many of the circuit board components, making test and replacement problematic, at best.
I just fixed! Turns out when when the audio on the left port goes out and everything seems to be fine, the chip on JP310 pins 8 and 9 need to be soldered together, easy way to check you got the right pins is to put a paper clip connecting the two and see if the sound goes threw. Dont be afraid to have it powered while testing, the current isnt enough to hurt you if you touch something bad. If u dont believe touch your ****** to it, a slight tingle will follow ^_^
Posted on Jun 06, 2012
  • 1 more comment
  • David Robertson
    David Robertson Jul 29, 2017
    WOW! This works! Thank you! I even tested to make sure this doesnt just re-create the right sound in the left. It actually gets stereo left and stereo right working again. THANK YOU SO MUCH!
  • David Robertson
    Update: I've also had long-time issues with the volume controller. So after I did this it stopped working again. I undid the soldering but it still wasn't working. So I looked to the volume controller. After some trial and error I got sound again. My fix: If you have a broken volume controller, you can strip the wire, and then touch together all the colored wires together (red, blue, light green, yellow and green) and then you will have sound.
  • David Robertson
    Update 2: Okay since I didn't want to completely give up and bypass the volume controller. I resoldered it closer to the box, effectively removing a good length of the wire, which was faulty. Now it works. I realized this may have been my issue all along - cable went bad midway. I will just have a shorter wire to the volume control now. Better than nothing ! :)
Try looking at your volume control connector. I found that 2 of the prongs were smashed down, so I got a tweezer and straightened them back up. As soon as I plugged it back in, the blue light on the volume control appeared (before it wasn't working at all), and the right side speaker worked again, whereas before only the left side had sound coming out of it.
Posted on Jul 22, 2009
    Problem Solver:
  • 6 Answers
Michael
Have had this happen every month or so. DO THIS.......switch ends of the main cable from computer to box.........presto......works every time. Also pull off the volume bass control off and blow out with air duster.
Posted on Jan 06, 2012
    New Friend:
    Problem Solver:
  • 7 Answers
Sdzxczxc
Posted on Jul 29, 2017
    Scholar:
  • 121 Answers
Have you tried looking in the audio section of the control panel and made sure that the balance isn't all the way to the right? There's my easy fix... Hard fix? Check soldering...and have hours of fun doing it ;)
Posted on Mar 26, 2007
I have Creative I-Trigue L3800 Speaker System, but I only get a redlight, won't power up. The Power supply works. What else can I try?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
hope it helps
Oct 05, 2011 | Creative Labs I-Trigue L3800 Computer...
My I-TRIGUE 3400 wont work with windows 7 unlimate 64 bit
Hello
First be sure you have downloaded and installed the correct sounddrivers.Meaning win 7 64 bit.
Not to be confused with 32 bit.You need 64 bit.
Next go to control panel,sound.Click on speakers then configure.Choose quadrophonic or 5.1.
Then run a test on each.
Also go to properties.and be sure the levels are turned up.
You may need to reboot after you do this for sound to work.
Sep 22, 2011 | Creative Labs i-Trigue 3400 Computer...
Suddenly, my speakers won't make any sound. this morning they worked perfectly, and i've checked the input is fine (it works well when i plug headphones in the volume control) and if i plug my ipod, still...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 01, 2011 | Creative Labs I-Trigue 3220 Computer...
Hello. I have a speaker system from Creative called I-Trigue 3400th I have come to uninstall the driver, so I want to hear where I can find diveren again. Thanks in advance for your help. Sincerely, Irene...
the driver you uninstall ed is for your sound card whats the model of your computer and if you know what type of sound card did you have inside. I can assist over skype remotely aryon314
Mar 01, 2011 | Creative Labs i-Trigue 3400 Computer...
Have an I-TRIGUE 3600 2.1 speaker for my
re-install drivers 4 audio or change settings
Jul 16, 2010 | Creative Labs Inspire T3000 Computer...
Power is on. Computer is working fine and
it seems that there is some problem with driver ,,,check the driver ,,,,, update it............. it will work fine
Jul 03, 2010 | Creative Labs I-Trigue 3220 Computer...
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
My Creative I-Trigue L3800 speakers have stopped working. The system receives power (the volume control lights up) but I am no longer getting any sound. I fear something may have blown but not sure what. I...
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
Oct 29, 2009 | Creative Labs I-Trigue L3800 Computer...
I-trigue 3600 No sound out of thespeakers, earphone jack is ok
I'm pretty sure the power stage is fused on these- check those first, they're mounted on the amp board inside.
Aug 12, 2009 | Creative Labs I-Trigue 3600 Computer...
No Sound
Make sure you plug into the GREEN speaker port on the PC.If using a digital connection,try going back to analog.The difference is almost non-existent,and much less hassle.
Oct 21, 2007 | Creative Labs I-Trigue 2.1 3300 Computer...
Creative Labs I-Trigue 2.1 3300 Computer Speakers Logo
3,984 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
