Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Green Swooping Band on Top Of Screen JVC- 56WP74
I had to put my Tv in Storage for a Couple of months when I Took it out of storage the band appeared everything else is find a far as the sound on the tv but the piture seems to have double blurred screen
  • 5 more comments
  • msdeb36 Dec 17, 2008
    Well at the top of the screen its like a green rope coming towards the middle of the screen and it stays there, and the top of images have blurriness
  • amitchell Dec 19, 2008
    Would love to know the problem
  • davelindsay2 Dec 28, 2008
    I have the same problem only with the blue... big blue swoop on top and bottom
  • ceitel963 Dec 30, 2008
    We have the same problem with the swirl on the top and double/blurred vision, is this fixable?
  • Anonymous Jan 06, 2009
    need to find out where to get the convergence board at to fix this.
  • jykovacs Mar 04, 2009
    can you tell me what resister to replace or were to find it thank
  • Kim Johnson May 11, 2010
    Please, can you give a more detailed discription
Your convergence chip, or chips are gone. Easy to replace on this TV via front access panel. Remove the front speaker panel open up the access port and remove the front board. Get the IC's online and solder them in and replace, Make sure to check all of the resistors as they also blow and replace as needed. Make sure to use a good thermal paste like MX2 as this is the baser problem as to why these fail (you will see what I mean when you remove the chips)
Posted on Dec 30, 2008
  • AAjax Dec 30, 2008
    Additionally to my fix above, DO NOT REMOVE THE REAR PANEL.
    These TV's have a sort of self destruct issue with the dvi port if you open the rear of the TV without taking the proper precautions, and there is no need to do so when you replace the IC chips.
    http://www.hometheatershack.com/forums/d...
    Best article Ive found on this issue
I need a manuel for an Amana refrigerator model AAF2534FEW
Double check your model number that number appears to be incorrect
Appliance 911 Sea Breeze
Sep 28, 2015 | Amana Refrigerators
I have a Philips 50 DLP HDTV MICRO DSPL and I figured the lamp was about to go out because after you would watch tv for about an hour and a half the picture would begin to flicker so I replaced the lamp...
A couple of things to check here. When you replace a lamp some TVs require you to reset the lamp hours meter in the settings in the menu (More common in projectors). If you do not do that then it will only run so many hours before shutting off again. If it is that, you should be able to turn it off and have enough time on the screen to reset that. If that is not the case then you should look into replacing your power supply board.
Aug 23, 2014 | Televison & Video
Everything is connected but there is no sound coming through
was it working before you put the vehicle in storage? if just the audio is not working, there is no code. as far as i know pioneers do not have security codes. you might want to check your speaker wires and speakers for shorts and bare wires.
Oct 01, 2010 | Pioneer DEH-1800 CD Player
32'' flatscreen (CRT) JVC I'Art tv will not turn on
I remember Jvc put out a service document about changing 2 transistors in the power supply..they are surface mount on the solder side of the pcb. You might not find the parts anymore unless your very tech saavy. Sorry man..
Jul 22, 2017 | JVC Televison & Video
My rca r52wh74 turns on for 10 secs then off.
was the storage unit climate controlled? If not then it's most likely due to heat and or humidity in which case I would suggest cleaning out the tv from the inside if you want to spend the time to do so but there is a good chance that the tv will need to be replaced.
May 31, 2009 | Televison & Video
JVC AV-32950. No sound after being in storage for 1 year
it may be dry points near audio circuitry
Mar 25, 2009 | JVC AV-32950 TV
Need driver for PRAKTICA DC Slim 315
Sounds like you have set it to PC Cam mode. If you put it in Mass Storage mode, you don't need a driver to use it.
To put it in Mass Storage mode: Hold the Mode button while it's turned on. Select the 3rd option that appears (looks like a Swiss army knife) by pressing the button to take a photo.
Scroll down and change USB Mode to Mass Storage.
Dec 29, 2008 | Cameras
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
