Question about Archos PMA 400 (30 GB) Digital Media Player
Archos pma 400 usb device does not recognise
I am having archos pma400 30 gb which i connect to usb port but this device is not recognised can you please assist me and secondly it can not be started and it show green light only but screen is blank can you help me in solving this problem
    Genius:
  • 1,061 Answers
Device drivers are not loaded or not loadwed properly.uninstall them and go to the web site and download new drivers.they should then recognize the player.RICHARDM69
Posted on Dec 17, 2008
Why doesn't scanner recognise usb connection
What type of device are you trying to connect to the scanner? The USB connection might not be working because the scanner can't register the device. It might also be a bad USB port. Have you tried a different device in that same port?
Elisa Jed ' http://www.azvalleygeeks.com
Jun 23, 2014 | Computers & Internet
CProblems onnecting Archos 700 after connecting 605 to PC
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Thanks,
Lee
Sep 21, 2008 | Archos AV700 Digital Media Player
Xl 400 futura singer usb port not connecting problem
Your USB not yet recognised, You may have to manually install new device or hardware till your PC reads your new device is ready to use.
Nov 03, 2013 | Singer CE-100 Futura Computerized Sewing...
Archos 2 OC won't charge and is not recognised by laptop
Sometimes with mp3 players the cable is the one that is mostly damaged. Try replacing this cable and try again. It actually has happened to me on two different mp3 players. Cables are always faulty.
Jul 12, 2012 | Archos 2 (8 GB) MP3 Player
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
Feb 06, 2009 | Archos 605 WiFi Digital Media Player
Not recognised under USB
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Archos not recognised by both my computers
You must update the firmware on the archos.
Dec 07, 2007 | Archos 605 Digital Media Player
Archos PMA 400 (30 GB) Digital Media Player Logo
118 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
