Question about Intel Motherboard
Can i use the 15 pin connector at the back of my laptop computer to connect to a PLC/
    Novelist:
  • 85 Answers
Ya u can use but 15 pin female connector is available in your laptop....
god luck.....
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Posted on Dec 20, 2008
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Dell inspiron 1520 how do i connect to my tv
The Dell has a VGA port 15 pin DSub connector and if your TV has a 15 pin viseo connector the you need a 15 pin video cable. Check the connectors on the Dell and TV so you get the correct connectors. You will need to select the computer input on your TV so it can display the Dell computer video images.
Apr 17, 2012 | Dell XPS One All-in-One TV Desktop with...
Hi my laptop went in for repair and they said it cant be fixed as the vga isnt working? what is this and could it be solved
A Video Graphics Array (VGA) connector is a three-row 15-pin DE-15 connector. The 15-pin VGA connector is found on many video cards, computer monitors, and some high definition television sets. On laptop computers or other small devices, a mini-VGA port is sometimes used in place of the full-sized VGA connector.
DE-15 is also conventionally called RGB connector, D-sub 15, mini sub D15, mini D15, DB-15, HDB-15, HD-15 or HD15 (High Density, to distinguish it from the older and less flexible DE-9 connector used on older VGA cards, which has the same shell size but only two rows of pins).
VGA connectors and cables carry analog component RGBHV (red, green, blue, horizontal sync, vertical sync) video signals, and VESA Display Data Channel (VESA DDC) data. In the original version of DE-15 pinout, one pin was keyed and 4 pins carried Monitor ID bits which were rarely used; VESA DDC redefined some of these pins and replaced the key pin with +5 V DC power supply.
the only solution for that is to replace your vga.
May 31, 2011 | Computers & Internet
I need to replace the VGA cable on my Sanyo projector, model PLC-XW55. I don't know what to get. It's a male-male cable .
Hi hotpinkvalen
If you have a VGA cable, take it to a computer shop or **** Smith and buy a new one.
Just tell them you want a VGA cable. It costs $6 to $10 depending on the shop.
If you don't have one, and if you don't know how it looks like, goto any desktop computer and have a look at the cable which is connected from the computer to the monitor.
It is a male-male cable both ends of the cable have 15 pins.
Hope this will help you
Best of luck
luciana44
http://www.sanyo.com.au/support/instruction-manuals/plc-xw55-instruction-manual
Oct 01, 2009 | Sanyo PLC XU35 Multimedia Projector
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Connecting Ibook G4 to Sanyo PRO xtrax projector
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Feb 02, 2008 | Sanyo PLC XU33 Multimedia Projector
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
