Question about Cuisinart DGB-500 Coffee Maker
Cannot get "beeping" to stop
I have checked the manual and it gives no trouble shooting to stop beeping. I opened the cover after it was done brewing but still "on" and now I can't stop it from beeping unless I unplug it.
  • mike55369 Jan 18, 2009
    I brewed a pot of coffee, re-programmed the time and now the coffee maker will not stop beeping so I had to unplug it.
    Problem Solver:
  • 6 Answers
Try the following if you opened the cover and unit beeps. This will happen if you set up the coffee maker and then decide that you want to add more water and coffee before starting it:
You will notice that there is a small white (typically) button on the clear cover of the coffee grinder. When it is in place and the lid is closed, the button depresses a safety interlock inside a small plastic post to prevent the grinder from working without the clear cover on and the lid closed. Quite sensible from a safety perspective. Depress the white button to reset the switch or take a pen and carefully do the same. The beeping should stop.
Posted on Jan 21, 2009
My new dryer Bosch Maxx6Sensitive begins to work for3or4minutes in every program I put it,but it stops then and it makes the beep-beep signal like it has finish the process and it shows on the little...
please go top the manufactures website and download the user manual it normally free and look in the trouble shooting section for the answerer eric
Dec 20, 2017 | Washing Machines
My Platinum brewer has begun brewing on it's own.
They advised me to stop using it and buy a new one. and why do you not listen to them
Nov 26, 2017 | Keurig Platinum B70 Coffee Maker
I am having trouble buttonholling on my Janome, it is new. It starts sewing and then stops and blinks 6L. What have I done wrong
Check your manual and follow the instructions. The error message may be listed in the trouble shooting at the back of the manual.
Probably will need to put on the buttonholing foot, pull down a lever which guides the machine to sew the length correctly and choose a buttonholing setting on the stitch selection.
Also, for good buttonholes, always interface the fabric to give it stability.
Mar 28, 2011 | Janome 8080 Computerized Sewing Machine
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
My cuisninart won't stop beeping, but every part seems to be in place how can I fix the problem?
On the Grind and Brew coffee maker the beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken. If you open the cover after you have started the auto-brew, it will beep but you can stop the sound by using a pen to gently depress the switch inside the small plastic post.
Dec 29, 2008 | Cuisinart DGB-500 Coffee Maker
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-500 Coffee Maker Logo
712 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
