Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series 20702 will not spin or drain
Washer will not spin or drain but you can hear a motor running when attempting to engage the spin cycle
  • 2 more comments
  • deeray41 Dec 21, 2008
    Thanks, actually, it will drain so the coupler is most likely the problem. Ready to try a fix but can't figure out how to remove the shell. Help! Pictures would be nice.
    Thanks kelly, I removed the shell, found the coupler, it was still intact although loose when fitted with the white plastic discs. I refitted the white discs around the black coupler and put the machine back together. Same problem, no spin, It wasn't necessary to tap the coupler back on, it just fit into the shaft. Should I try a new coupler and go from there? If it is not the coupler, then what? The coupler was old but not desintegrated, it had some wear but looked ok.
  • deeray41 Dec 23, 2008
    I'll check for the clicks. Since the coupler is inexpensive, I'm going to replace it and see what happens, If no success, I will relunctantly call an expert.
  • deeray41 Jan 14, 2009
    Thanks, finally located a coupler (metal shaft, not plastic), replaced the broken coupler and the machine is fixed.
  • 20 Answers
It sounds like your coupler is broken, with the machine unplugged and with help pull the washer out and then tilt it back. look between the motor and the transmition for a back disk sandwiched between 2 white disks. if it is gone then you need to replace the coupler. it is a medium difficulty job, you need to take the shell off in order to do the job.
Posted on Dec 19, 2008
  • 1 more comment
  • Kelly  Smith
    Kelly Smith Dec 21, 2008
    well i cant do pictures but i can talk you through it. ok 1st, look for two screws on the consul were the timer and knobs are. they should be in the corners near were the consul and the top of the machine meet. or if they are not their then they are behind the panel on the back of the consul. once you have those screws out then you can flip open the consul (unplug first). once you have the consul up there are two brass looking clips on either side, take a long screw driver and slide it straight down into the little up curved portion of the clip and then push forward on the screw driver popping the clips out. once those clips are out you can lift the shell away free. once the shell is off take your screw driver and slide off the clips holding the pump on and then the clips holding the motor on. P.S. unclip the top clip from the motor first and when you put it back put the top clip on last. you should see the coupler right their, make sure you have the new one first. just pry the old one off and tap the new one on with a hammer and dowel or something comparable. now reverse these steps and you should be done. kelly
  • Kelly  Smith
    Kelly Smith Dec 22, 2008
    when you took the coupler off are you sure there wasn't a crack in it? in the plastic white disks, were the pegs still on the white disks? if the lid switch is fine and you hear click click when you open and shut the lid and the coupler is fine and you hear the motor running the machine should work. if not then you need to call and expert. kelly
  • Kelly  Smith
    Kelly Smith Dec 23, 2008
    ok, good idea to replace the coupler. P.S. don't use Sears. kelly
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer model # 110 20702 990 will not run past washer cycle or drain water
That is going to be your lid switch.
On this washer the pump is mounted on the motor. The motor goes in one direction for wash and the other for spin. The water gets expelled from the washer in the spin mode.
Here is 4 videos a service manual and a brief description of how it all goes down:
How it works: Direct drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 22, 2011 | Kenmore Washing Machines
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kenmore 24932 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
648 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
