Question about Samsung MW4350W Microwave Oven
Power level again
I need to know the exit power in watts of the oven microwave samsung mw4350w, their intermediate levels of power in watts and how I can configure them with the button but in the page of support of samsung www.samsung.com/support/productsupport/download/index.aspx or www.samsung.com/support/index.asp they do not give that information me.
  • Samsung Master
  • 9,150 Answers
It is probably a 700 watt model. Most ovens have 10 power levels, ranging from 10% to 100%. Normally you press POWER LEVEL, then press 1 for 10%, 2 for 20%, etc., then press START or COOK to cook. We could not find exact information on this model.
Posted on Apr 10, 2007
What is the wattage
Wattage refer to the power level of the machine. The higher the watt number the more power full is the machine - for example a 900 watt microwave oven will boil water quicker than a 500 watt oven.
Mar 14, 2016 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How to set temperature in Samsung microwave. 160 c means ? watts.
They're totally non-interchangeable as they're two totally different ways of cooking.
There is no correlation at all between a temperature setting used by electric and fan ovens and the microwave power level, there's not even a rule of thumb. For microwave cooking, the fat, sugar and water content of any given food item as well as the mass and shape are what determine cooking times and microwave power levels, and not all foods can be safely microwaved as high fat/sugar content foods may catch fire.
Jul 06, 2011 | Samsung MW4699S Microwave Oven
WHAT IS THE WATTAGE ON MODEL # MW880BSA?
The rating will apear on the rear of the machine in the identity label.
Mar 21, 2011 | Samsung MW4350W Microwave Oven
I just want to know the wattage of the MW6471G
You can find the power of this oven on the back of the oven, it is marked as Power Consumption. Whatever the number is the power of your oven. For example if the power consumption is 1200 watts then your oven is a 1200 watt oven. I hope this helps you.
Have a great day!
Carol.
Mar 03, 2011 | Samsung MW6470W/MW6471G Microwave Oven
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Detemining the Wattage of a Samsung Microwave Oven
600 watts.
Samsung MU3050W Microwave Oven Consumer Rating: sdc_stars_sm_5.gif See 1 review | Write a review Information: Product details | Product accessories 1-Stage Programmable Cooking. White Cabinet. 15 Min. Timer Optional Mounting. 0.5 Cavity. 600W Output Power IEC-705 Mech. Control Type. MW Distribution - Turntable. 1 Power Level.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Samsung Microwave Ovens
Power levels
You can download a manual that's close to yours here: http://www.samsung.com/support/productsupport/download/index.aspx Or contact Samsung for the exact answer: http://www.samsung.com/support/index.asp
Mar 18, 2007 | Samsung MW4350W Microwave Oven
Power
You can download some models' owner's manuals here: http://www.samsung.com/support/productsupport/download/index.aspx But the attached diagram shows how power levels are categorized or rated. When you want to cook at a power level other than high, you normally hit POWER then a number from 1-0. On some models you press POWER repeatedly until it shows the power level you want.
Mar 14, 2007 | Samsung MW4350W Microwave Oven
Microwave Ovens Logo
209 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Simon Flummox
Simon Flummox
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
