By Luisa_K - usenet poster
Our Hamilton Beach food mixer Model 210 [1960 variety] has started running hot while being used for cake mixes etc [as opposed to heavier mixing i.e. bread dough] I plan to clean out the motor area, check brushes etc. Any other suggestion that I can try prior to possibly replacing the unit?
Best Solution
posted on Aug 08, 2005
kcw573 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
These motors can fail in a number of ways:
Open windings - this may result in a bad spot, a totally dead motor, lack of power, or excessive sparking. Windings can open from a major overload/overheating episode either melting the wire or solder connections (the latter on the armature usually), defective manufacturing and thermal cycling, or damage during servicing.
However, the source of the open may not be the windings but a blown thermal fuse - see below.
Shorted windings - this may result in excessive current, severe sparking, reduced speed and power, and overheating. The thermal protector, fuse, or circuit breaker may trip. Continuing to run such a motor may result in a meltdown or burned coils and insulation - i.e., a burned out motor.
Worn carbon brushes - while these usually last for the life of the appliance, this is not always the case. The result could be erratic or sluggish operation, excessive sparking, damage to the commutator, or a motor that does a pretty good imitation of a paper weight :-).
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Varimixer 746 Watts W20J Stand Mixer
Email this problem
Email this problem
This Problem Also Relates To:
Kenwood 800 Watts KM800 Major Classic Stand Mixer
Applica 125 Watts WMX20 Hand Mixer
Applica 200 Watts WHM6 Hand Mixer
Black & Decker 250 Watts MX300 PowerPro Hand/Stand Mixer
Bosch MUM6612 Universal Series Mixer
Black & Decker 200 Watts MX85 PowerPro® Hand Mixer
Bosch 400 Watts MUM4420UC Compact Series Stand Mixer
Can you Help with these Mixers problems?
Repair Service
Find Mixer Repairman Near You:
