Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
Single handle Pioneer shower faucet will not allow enough hot water. Water comes out luke warm. How do I adjust this faucet?
  • 4 more comments
  • Anonymous Mar 15, 2014
    is there a way to increase hot water by adjusting handle ?
  • Anonymous Mar 16, 2014
    Pioneer shower fauset drips
    Pioneer shower Faucet drips
    shower faucet made by pioneer drips
  • Anonymous Mar 25, 2014
    shower faucet rattling when opening the lever handle
  • Anonymous Mar 31, 2014
    hot when turned all the way - not range of warm
  • 68 Answers
Its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
I have a Grohe shower system that has the temperature control it was working fine and now the water only comes out luke warm. the handle goes from 65 degrees to 110 degrees. I live in a older highrise...
WEll, the question is do your sinks have water that is hot enough? If no, perhaps your water heater is set too low. If yes, many shower controls have hot limiter and if you pull the handle, often there is a spline assembly that stops the travel from going hot, adjust to allow more.
Dec 13, 2010 | Grohe Home
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
I turn it all the way towards the hot but my water will only get luke warm. i try tried to fix it myself but only got as far as unscrewing the base.... Can you tell me what to do?
Take handle off of shower faucet and it will have a dial to remove and adjust to proper flow. Just remember where it is at. Remove it and move it about 1/8 to 1/4 turn counter clocwise and reinstall to increase to hotter temp.
May 21, 2010 | Moen Posi-Temp Single HandleTub And Shower...
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
I have a new single handle shower valve and when i turn it to hot it only gets luke warm, i have taken the cover off and i see the brass piece with a screw in it but it does nothing to adjust it and when i...
single shower units are shipped in cold position as a safety u have to adjust ur anti-scold clips to allow hot water --- that red clip is ur hot adjustment-- if u have ur paperwork for the unit in it explains on how to adjust[ but]=== if u pull back the red clip [it sits on a spline of teeth] and turn it put back on so the valve opens do it in small increments till ur comfortable with hot adjustment will take a few times
Mar 01, 2010 | Moen & One Handle Tub & Shower Faucet
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
No hot water
under the handle of the faucet reached by removing the covering cap and single screw is a plastic geared device which limits the travel of the handle to the hot side carefully reorient so handle will turn a little farther and reinstall handle screw and cap
Jul 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
1,499 people viewed this question
Top Pioneer Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
