I want to send a fax with more than one copy. What is the manner to succeed with this operation.
  • Dan
    Dan May 11, 2010
    So I am clear, you want to send the same fax 2 times to the same person?
    Guru:
  • 829 Answers
If you want to send to more than one fax number, just separate the numbers with commas (just like you would when you’re addressing an email to more than one recipient).
Posted on Dec 17, 2008
OUT OF MEMORY TRYING TO FAX
<Fax sending or copy operation in
progress>
Do one of the following:
- Press [Start] key to send or copy the
scanned pages.
- Press [Stop/Exit] key and wait until
the other operations in progress finish
and then try again.
- Clear the data from the memory.
<Printing operation in process>
- Reduce print resolution.
- Clear the faxes from the memory.
Apr 02, 2014 | Brother MFC 8950DW
Lexmark Productivity Suite --the faxes don't go through -- error message
Are you able to send faxes when using the printer operator panel - not through Lexmark Productivity Suite application on your computer? Are you able to receive faxes without any problems? Make sure the fax line where the printer is connected is working properly. It could be a signal quality in the connection.
You can also try to decrease the transmission speed when sending faxes. On your printer operator panel:
  1. Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
  2. Press Select.
  3. Press Options ten times until MAX SEND SPEED appears on the LCD display.
  4. Change it to 9600 BPS using the - (left arrow) button.
  5. Press Select.
Try to send your fax again.
Source: Problems Sending a Fax to Specific Fax Machines
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hello all I have a hp 4315v all in one printer /fax and i would like to see if the fax is working is there a test number i can use to test it out with
HP has a Fax no. to test.
Send any test page as fax on the 1-888-473-2963 and wait till it is send. Once the fax is sent, you will receive a fax as notification ( confirmation ) of the fax being received by HP.
This above no. sometimes is busy so you may need to give couple of tries till you succeed.
Or the best way is to send fax to any of your friend who owns a fax machine and ask them to send fax back to you.
Regards,
Ron
Mar 07, 2011 | HP OfficeJet 4315V All-in-One Printer
Several recepients cant read my fax, very feint. Is it a fault with my fax?
Try making a copy on your machine and see what the copy looks like.
What are you sending,??? if its a second carbon copy of something...remember what you see is what you get...if the original is poor quality the receiver will get poor quality. You can darken the image slightly...refer to your operators manual.
Jun 16, 2010 | Samsung SF-560 Plain Paper Laser Fax
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Sharp MX-3501N ---- My copy machine you can hear sending out the fax, it dials and then sends and then beeps really loud. Is there any way to shut the sound off so we don't hear the fax go through?
There's a Key Operator setting for muting the fax speaker. Press the 'system settings' button, then the Key Operator button to enter the access code to the key operator settings (default is all zeros),
Find the Fax settings button and then the fax default. The option to mute the speaker should be within the speaker volume settings.
Aug 18, 2009 | Sharp Office Equipment & Supplies
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Fax
i need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Jan 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
k24674
jasbo
jasbo
