Hello, My WDI12c Smeg washer dryer shows up error code E05 and beeps. This happens about 5 minutes after I put it to a wash cycle. Interestingly if I move it to a program with prewash it will prewash and then stop. I have checked the hoses and filters they are fine. Any help would be appreciated.
I am having the same problem and would love to know how to do the "RESET" of the unit - any help?
ThanksHello....
Thanks
AnonymousMar 14, 2014
smeg washing machine 16AAA is showing error code E05. Began to fill then stopped and started beeping. What to do?smeg washing machine 16AAA is showing error code E05. Began to fill then stopped and started beeping. What to do?
Smeg washing machine model 16AAA is showing error code E05. It began to fill then stopped and started beeping. Any ideas what we can do?Smeg washing machine model 16AAA is showing error code E05. It began to fill then stopped and started beeping. Any ideas what we can do?
AnonymousMar 18, 2014
error code e05 on smeg s850 washing machine , machine stops part way through the spin cycleerror code e05 on smeg s850 washing machine , machine stops part way through the spin cycle
AnonymousMar 23, 2014
Smeg WMF147x gives Error 05, only for wash cycle. The rinse and other cycles work fine. checked troubleshooting guide, all checks are fine.Smeg WMF147x gives Error 05, only for wash cycle. The rinse and other cycles work fine. checked troubleshooting guide, all checks are fine.
Smeg WMF147x gives Error 05, only for wash cycle. the rinse and other cycles work fine. checked troubleshooting guide, all checks are fineSmeg WMF147x gives Error 05, only for wash cycle. the rinse and other cycles work fine. checked troubleshooting guide, all checks are fine
You can't post conmments that contain an email address.
Washing machine error code E05 usually refers to the hot water temperature sensor at the back of the tub, it's not sensing a temperature change. It's not an error that can easily fixed by the user, so it is not listed in the manual. It could be the sensor itself, the heater, the controller or the wiring. Call for repair.
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Hello....
Thanks
