Question about Brother SE-270D Computerized Sewing Machine
Embroidery machine patterns are not consistant
Recently did 4 of the birthday cake design. The designs do not sew in the correct places. When the entire pattern is done it does not cover all the space and some are covered up. What can I do? Brother SE 270D Disney machine
    Problem Solver:
  • 6 Answers
I'm just beginning to work with my machine, but I have had a similar issue. Some of the possible solutions that I have found include (note: I've tried #1, I will try 2 and 3 soon)...
1. use stabilizer fabric.
2. if you're using tear-away stabilizer, and it is tearing prematurely, try a cut-away stabilizer (or maybe iron-on stabilizer?).
3. if you're embroidering on fabric like fleece, try 'hoopless embroidery' This involves using adhesive stabilizer - put the stabilizer in the hoop with no fabric, (if you don't have adhesive stabilizer, use regular stabilizer and spray it with a craft adehesive) then lay your fabric over the hoop and press the fabric onto the adhesive.
good luck.
Posted on Dec 22, 2008
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Brother embroidery machine
Hai, What type of your embroidery machine? How many heads and needles? If your machine 4 ,12 or 20 heads and 6 or 9 needle, you can use different color and designs.
Apr 10, 2014 | Brother Sewing Machines
How do you place an embroidery design from a card into the machine memory? I have a ESe2. Thanks!
For the Brother NV1500 (aka Babylock Esante ESE2).
Bring the embroidery design onto the screen.
Press the save button in the upper right of the screen.(it looks like a pocket)
See pages 141 to 143 of your instruction manual "Saving Embroidery Patterns In The Machine's Memory"
Mar 18, 2014 | Baby Lock Esante
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
I have a Designer1 embroidery machine. It sewed
Have you tried another emb pattern for something else 1st? could just be a bad disc pattern
Jun 30, 2010 | Husqvarna Sewing Machines
I recently purchesed a Singer Futura CE150 embroidery sewing machine and I'm having some broblems.I bought some embroidery designs off the internet from a co.by the name of embroidery library and the...
Multihoop and endless hoop features are not supported yet. If you have purchased a design that splitted to several parts, you need to place them in the proper order and from the proper position manually.
Dec 22, 2009 | Singer CE-100 Futura Computerized Sewing...
Can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.   Cheers, Ginny
Ch
Dec 10, 2008 | Brother Disney PE-400D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
122 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
