Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-45VA1 ~ No Projection Image
One evening I went to turn on my ever-faithful 1992 Mitsubishi VS-45VA1 T.V. with my remote but it wouldn't turn the T.V. on. Thinking that the batteries in the remote were exhausted, I immediately replaced the batteries. But, the remote still failed to turn the T.V. on. It was necessary for me to turn the T.V. on manually at the set. But the screen remained black (not even the normal blue when no signal is detected). I did however get audio from the speakers. I checked everything that I could as far as the settings go. Everything looked normal. After reading around these types of repair websites, I read where someone suggested unplugging and then plugging in the 120VAC power cord for someone else's T.V. problems. Well, I just decided to try this and it actually worked for my problem. I'm guessing that this may have reset some electronic relay internally, but don't really know for sure. Do you got any ideas on what component may have been tripped or reset?
  • 1 more comment
  • LOUIS CARACCIOLO Apr 08, 2007
    This same thing has happened on two other occasions, but pulling the AC power cord and plugging it back in seems to be the solution for the time being. It's probably time to start looking at the new Mitsubishi 1080p DLP's.
  • Anonymous Apr 13, 2008
    audio no vidio. but a blue screen with the menu .
    audio no video . but a blue screen with the menu when menu button pushed .
My mitsubishi rear projection tv had leaky caps at PIP board. you can bypass by purchasing caps at radio shack. i found a web site showing how to fix it. i heard they are very common. i can not recall what site though. i replaced mine and worked fine.
Posted on Aug 20, 2007
THIS MAY ALSO MEAN THAT THE LAMP IS LOSING HRS AND NEEDS TO BE REPLACED
Posted on Aug 08, 2007
    Novelist:
  • 192 Answers
Sometimes resetting the microprocessor circuit is all it takes to fix a set. A shock, power fluctuation or something in the timing of the control circuit may have caused a momentary glitch in the television and resetting it fixed the set. Keep an eye on it and if there is another problem with it, reply here and we will try to work it out.
Posted on Apr 08, 2007
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
I have the same problem, but i didt myself
replaced the convergence ics if you have concave triple colored images on the screen.
Jul 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
May 14, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Blue lines in screen
Sounds like the blue crt is either shorted or one of the resistors on the blue CRT PC board is open
May 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Screen protector??
Screen protector, it is a glass or type of plastic that covers the original screen, this can be purchased from places like Sears, Mitsubishi, MCM, etc.
Nov 16, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Picture has greenish tint that I can't adjust out
There is a crt drive problem and you can isolate it by unpluggin g the set, removing the green crt socket, in the middle of the three tubes is the green tube by the way, remove one of the other tubes and switching the crt sockets and turn it on. If the set is still greenish, then the green crt is bad and needs replacement, if another color is primart, then it is going to be the green crt drive circuit and is going to need to be serviced. Good Luck
Oct 07, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
