Question about Sony CPD E230 17" CRT Monitor
Monitor I can not access anything on my computer becasue the monitor is in power save mode. It does not come out of that mode when i restart. There is just a little box on the screen that says "power save mode" so i cant get to any of my computer settings.
  • James Godsey Jan 18, 2008
    same thing i cant get out of power save mode cant use pc because cant get pass bootup logo after that screen goes blank
  • 624 Answers
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t139319-monitor
Posted on Mar 25, 2007
No sleep mode on acer monitor
This is annoying, but try to go back on factory default setup.
Apr 15, 2014 | Acer Computers & Internet
Have a Dell E228WFP monitor keeps going into power save mode.
does it go into power save mode with your actually doing something. Like for instance if your typing does it go into power save mode? If its going into power save mode when your not doing anything on it then its as simple as a setting either on the monitor itself or in the power settings within your computer accessible by the control panel and screensaver
Jul 22, 2012 | Dell E228WFP LCD Monitor
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Will not leave power save
This could be a computer problem more than a monitor problem. To check the monitor disconnect the video cable from the back of the monitor and see if you get any colored lines. If yes then the monitor is file. If even with the video cable disconnnect the monitor shows power save mode it a bad monitor. If you get the lines then you need to troubelshoot the computer. Try powering off the computer and then power it on and tap F8 as the computer restarts. If you get any display it should be a screen with the options safe mode etc. Select safe mode and start the computer up and once at the desktop restart, Let me know if this helps.
Rate if useful.
Aug 11, 2009 | Dell 1704FP LCD Monitor
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Sony CPD E230 17" CRT Monitor Logo
241 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
