Question about Tekram S3Pro Au Motherboard
My only problem is that i dont know where do i have to put the plug of the speakers in to the board
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
On the pack panel of your cpu you find the plugpoints where u can plug in the the speakers
Posted on Dec 17, 2008
No audio
Dave, This is a hardware problem, this is a speaker problem (ringer), the speaker and ringer is same part, so maybe it is unpluged on board so it is not working, try to dissemblay the device (if you dont know how to open see this video : http://www.youtube.com/watch?v=iECXQJF9IzU) and plug again the speaker to board also make sure if any connector on speaker or on board is not damaged, after this check your device if it started working speaker or not if problem persist change the speaker (if you dont know how is speaker look like, see the picture of speaker on following link : http://www.google.co.mz/imgres?imgurl=http://gsmserver.com/nfs/product/820512/image/500/Speaker-plus-buzzer-for-LG-KP500-Cellphone.jpg&imgrefurl=http://gsmserver.com/shop/spares/speaker_buzzer/lg/speaker_buzzer_for_lg_kp500.php&usg=__iu6k-yd6ignON9ZFm4yqzTSqQ0o=&h=500&w=500&sz=28&hl=pt-PT&start=2&zoom=1&tbnid=qt8Q_rMbkvGayM:&tbnh=130&tbnw=130&ei=ftX_T9D1LePR0QWD-rmfBw&prev=/search%3Fq%3Dlg%2Bk500%2Bspeaker%26hl%3Dpt-PT%26sa%3DX%26biw%3D1280%26bih%3D709%26tbm%3Disch%26prmd%3Dimvns&itbs=1)
Please don't try this at home if you think are not able to do this, show some official repairer to fix it. but temporary you can use headphone or bluetooth to communicate by your device. Best of Luck. If my answer was helpful please rate it.
Jul 12, 2012 | LG KP500 Cookie black on T-Mobile U-Fix...
No sound
Hi are you sure the mute button isnt stuck on your controll if this is not the case then it could be on the circuit board.
Have you tried changing the sound mode and see if this changes anything.
The only thing you can do if it is a board problem is buy seperate speakers that will plug into the audio out put connectors doing this will let you know if it is a controll or setting problem also if you try external speakers then you would no that it isnt a controll problem if you got sound through the external speakers then the chances are that it is a solder problem if the solder had gone on one speaker you could eliminate that as you would know where to look but as it is both the speakers, Im basing it on that you are using the speakers inside the telly and not external ones if you are using extra speakers unplug them and just try the telly ones.
So basing it on that you are just using the internal speakers then it could be a solder problem on the board where the speakers plug into.
It could be something as simple as a resistor gone or going these are cheap to buy but i dont sugest fitting yourself unless you have relevant testing equipment and a good knowlege of soldering.
So first i would try changing sound modes on the telly if this dont change anything try pressing mute button just to make sure that the controll and all its functions are working properly.
But after this if it dont solve your problem then you could either buy external speakers as this might solve your problem but if you want the telly working as it should be you will need all equipment and to be able to read a spec sheet and be able to follow cicuit diagrams.
Let me know how you get on and what you want to do
Dec 01, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Case has 1 small speaker in front but dont know where to connect to motherboard. speaker have 1 black & red wire on small female plug
Input the speaker's jack to the mother board,from back side or the front panel,which is green socket.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | Intel Motherboard
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
No sound on my computer
If it is the driver, you can download the audio software:
EliteGroup L7VMM2 Driver Downloads
If is is not, the most common error is not plugging your speakers into the correct jack on the back of the board.
Next most common problem would be "Volume Control" slider too low, speakers are muted or headphones are plugged in cancelling output to speakers.
I hope this helps!
Dec 22, 2009 | EliteGroup L7VMM2 Motherboard
Sound problems
your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
May 31, 2009 | Computers & Internet
Looking for plug in?
one output from pc to boopher and all output to speaker goes to speaker and plug boopher's volt line to ac line 220
Apr 26, 2009 | Computers & Internet
Which jack do i plug my speakers in & why dont they work in any
Plug them into the one that has the green ring around it,
you might have to config them in controll panel then audio settings :)
Feb 16, 2009 | Packard Bell Speaker Computer Speakers
Not all the speakers are working
hi Deadking
You have to look in the back, and down where the lan are, is the 5.1 sound card, you have some inputs there, I dunno what brand of speakers you have, but commonly you have to put according with colors, green, black, orange, or if you have only 2 speakers, just put on the black or green output. turn up the volume in control panel, and see if not on mute. good luck
Nov 20, 2007 | Logitech X-530 Computer Speakers
The speakers don't work
Ok There is another chance to work your speakers ,
  If you have your mother board CD , get play that  and  reinstall the sound system .
  I hope it will work ,      please do reply
Sep 06, 2006 | Gateway GMAX 2100 Computer Speakers
Tekram S3Pro Au Motherboard Logo
77 people viewed this question
Top Tekram Computers & Internet Experts
Robert Graf
Bill Boyd
JonSnell Electronic
JonSnell Electronic
Are you a Tekram Computer and Internet Expert? Answer questions, earn points and help others
