Question about Cameras
Sony camcorder power blown out by worng AC adpater
I have a Sony camcorder that uses a 7.8V 1.4A power adapter.My daughter plugged in a 24V 1.5A power adapter. It happened to have exactly the same connector.Camcorder no longer works.Is this a repairable problem? For less than $150?-eric
  • 78 Answers
Sorry,no.
Posted on Dec 18, 2008
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Im after a bush ac power adaptor for a LCDS20TV011
You could get one from ebay , but they seem very expensive. http://cgi.ebay.co.uk/24V-AC-power-adapter-Bush-1LCD23TV022-LCD-TV-/360224352429?pt=Televisions&hash=item53df0b68ad#ht_2521wt_1094 (It does say make an offer)
Other models may use the same supply and its cheaper, You could check with the vendor if a cheaper one is suitable for the Bush, after all why pay more for the same thing. http://cgi.ebay.com.sg/24V-AC-power-supply-adapter-BenQ-FP231W-Q23W3-LCD-TV-/330393378073 You just need to make sure the current/wattage and the plug on the end are the same.
Jan 17, 2011 | Bush 24v Ac Power Adapter For Bush...
When I put my adapter inside for charge my laptop turns off and the light is on saying that is charging but its doing nothing pls help. Regards
Read the article below, may it will help.
Laptop shuts off when AC adapter plugged in
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Jan 09, 2011 | Toshiba Tecra M5-384 Laptop AC Power...
The display says 'red disable' then afetr a sort while goes to the flashing disc full symbols. My problem is that it won't let me finalise so can't save the data and use the disc on other things like my...
Do you get finalize option as grayed/ disabled?
If yes then plug ac power adapter in camera and finalize the disc.
Camcorder wont finalize on battery and need ac charger to perform finalize the disc.
Jun 03, 2010 | Sony Handycam DCR-DVD201E DVD Camcorder
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  6. NOTES:
  11. NOTES:
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
Sony dcr-dvd101 won't Power On
hi
i think that your problem is in fuses
u must open it and replace the fuses u will find a diagram inside your camcorder to locate this fuses.
u can remove them and bypass.
bye
Jan 09, 2008 | Toshiba Sony DCRDVD101
No power
Probably blown fuse on the power board. If you hear a "pop" sound, you have blown couple of fuse along with some other components. When a small fuse blows you cannot hear any sound. Camera needs a new power board and repair cost may run from $175-275 depending on damaged parts.
Mar 16, 2007 | Sony Handycam DCR-TRV230 Digital Camcorder
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
