Question about Archos Gmini XS202 MP3 Player
Gmini hard disk reading problems
My Archos Gmini XS202s reads "Read access error! Can't read hard disk" When its turned on. I've tried formatting through the device, but it doesnt seem to have worked, can anyone help?
  • station1975 Jan 25, 2009
    Same here
  • Anonymous Feb 14, 2009
    i also have the same problem.. i am wondering how to repair the mp3 with the PC?
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Posted on Apr 29, 2009
Turn on hangs on opening logo screen..center button="Read access error! Can't read from hard disk."
Possible causes and solutions
1 The hard drive within your player has failed, not uncommon and a real pain to fix for all but the real hands on techies. requires replacement hard disk likely same size required.
(unfortunately most likely problem) it will probably be accompanied by an unusual clicking noise coming from the player when held to your ear.
2 The hard drive within your player has become corrupt or something similar and requires formatting. Simple for any IT person to do. I'm no expert on this model and am too lazy to check but even holding down the reset button for 30 seconds or so may fix it.
Good luck hope i helped.
Jul 24, 2009 | Archos Gmini XS202 MP3 Player
Archos gmini 402 camcorder
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
May 04, 2008 | Archos Gmini 402 Digital Media Player
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
May 22, 2007 | Archos Gmini XS 100 MP3 Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
Archos gmini xs 100
New hard drive. Mine died, too. klick-klack, rrr, klick-klack... end.
Dec 29, 2006 | Archos Gmini XS 100 MP3 Player
Hard drive
hi what probebly had happend is that you earased your system files along with all other (stupid manufacturer) you need to install your firmware again: http://www.archos.com/support/download/firmware.html?country=global&lang=en next thing to do is dowloding and insalling all links from this page: http://www.archos.com/support/download/index.html?country=global&lang=en good luck
Mar 30, 2006 | Archos Gmini XS 100 MP3 Player
Archos Gmini XS202 MP3 Player Logo
567 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
