Question about Toshiba 27A30 27" TV
Toshiba TV We have a Toshiba TV and at no certain time the tv will go off and then come right back on. Lately it will go off, on, off, on, & it will do it 2-3 times, but it always goes back on. What could be causing this.
    President:
  • 1,284 Answers
Try unplugging the set for about 2 minutes to reset the TV. The other possibility is a stuck button on the TV or a remote control near the set that is randomly sending out signals.
Posted on Mar 26, 2007
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
There appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
May 19, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Toshiba 43vs9ua rear projection tv picture problem
I also had a same one but had the same problem. Thinking of throwing it away!
Dec 25, 2007 | Televison & Video
Design Problem of TP55H60
call tech ..suggest soldering h-drive.
Jul 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Toshiba 27A30 27" TV Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
