Question about Canon CanoScan LiDE 30 Flatbed Scanner
I have an E-Machine and every time i click on the canon scaner it tells me to make sure my scanner is turned on and my connection wire are hooked up properly which they are. One question of mine is where is the on-off button this scanner for i can't seem to locate it.
    Sergeant:
  • 236 Answers
The power button might be in the back right by the power cord. If you see no button, your scanner may not have one. In that case pull the plug and reseat it to power it off and on.
Posted on Dec 17, 2008
Mon imprimente pixma mp810 donne un code erreur 5020 et demande de deverouiller le scaner
This correction is listed on the Canon website. Lock Switch Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
    Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
  3. Close the document cover.
  4. Press to turn off the machine.
  5. Wait approximately 5 seconds then press to power back on the printer.
Mar 27, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
How do i connect my epson scanner 3490 t0 my epson r220 printer
i am not sure if the two could be readily connect. but, you may connect them on two of the USB port on your PC at the same time.
Oct 07, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Convert canon canoscan N640P EX to use usb
please the old scaner programmi is unstoll and you go a run and add a scaner progremme cd instolldrriver orignal and start the scaner is on
just you used the window xp if fouto didate and give a usb cable and use a scaner
Sep 22, 2009 | Canon CanoScan N640P ex Flatbed Scanner
Cannot communicate with Scanner is a message and I am hooked up and my printer works, but not the scanner portion of the equipment.
My Vista computer tells me the same thing unless I use Picasso software to scan. I'm not sure the problem, but this Canon machine doesn't scan with all drivers...
Aug 13, 2009 | Canon MX310 Office All-In-One Printer
Scaner will not work? Says its not hooked to computer?
Hi! Check the cable of the scanner if it is properly hooked to your computer. Also check all the connection from scanner to the computer. Then turned on your scanner. GOOD LUCK
May 06, 2009 | HP OfficeJet r80 InkJet Printer
Hava not instalation disc for canon scaner Lide 20
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the scanner USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Number 6 cylinder misfire
That has to be either a bad plug in the number six cylinger, or a bad spark plug wire. First hook the scanner up and erase the code, then turn it back off. Check both ends of the spark plug wire and if they look okay, make sure they are firmly hooked back up.
Hook up the scanner and start the engine. If the code comes back, I would replace the plug at first, then hook your scanner up before the engine is running and erase the code. Then start the engine. If it comes back, then you know the spark plug wire is the culprit.
Note. If you erase the code and it doesn't come right back, don't be elated. It may take driving it a bit before it comes on again.
Sirwriter
Jul 02, 2008 | 1998 Oldsmobile LSS
Canon CanoScan LiDE 30 Flatbed Scanner Logo
29 people viewed this question
old marine
old marine
